Cars & Trucks Logo
Posted on Nov 07, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2002 chevy silverado 5.3L 2WD wont crank ,diagnostic tool read code C0226,could this stop it from starting?
Recently had new brakes installed, new battery, had starter checked by NAPA all checks ok. it wont crank or start everything turns on but it wont do anything, transmission is on park , tried putting on neutral but still nothing. I just found out about ani-theft code that might have to be reset could this be a possibility? am stumpted any assistance would be greatly appreciated! thank you ! Jose
Anonymous
Level 3:
Master:
  • Master 689 Answers
  • Posted on Nov 07, 2012
Anonymous
Master
Level 3:
Master:
Answers
689
Questions
0
Helped
100915
Points
1974
How did you find out the code? A good scranner if you no how to use it (Properly) Will all so show you what sensor detected the problem, End give you a idea what to look for,
5 Related Answers
Anonymous
  • Posted on May 15, 2009
SOURCE: Truck won't start something to do with Anti-Theft tried removing positive cqble to reset alarm nothing, possible wire off Anti Theft Unit Truck drove fine parked for one hour and went to leave, the en
not positive but look in owner manual for a fuel pump reset button i had this problem at one time and that fixed it it is usualy under the dash area somewhere on the drivers side or in a kick panel (decorative cover on the side firewalls inside the cab)....good luck i hope this helps!
Anonymous
  • Posted on Aug 21, 2009
SOURCE: 99 chevy cavalier theft system light on steady, car wont crank.
My 2000 cavalier has done this for 6 months. You take your key out then open your door, wait ten minutes and the system resets itself and the car will start-annoying you bet!!!
Anonymous
  • 101 Answers
  • Posted on Sep 10, 2009
SOURCE: 1994 buick park ave, wont crank over,
Pass key is the security system which disables the car if it is stolen. You need the remote or a key with a chip to start the car. go to a dealer, prove ownership with registration and they will be able to help you out
swoop611
Dave Sargent
  • 488 Answers
  • Posted on Dec 07, 2009
SOURCE: 91 Buick Roadmaster wont start....... Baffeling
If the engine will not turn over using the starter then it cannot be the fuel pump. If the car has a factory inhibitor system installed, the chances are that it is this system that is preventing the car from starting. You may not have to press a button on the key fob either, it may have a transponder built into the key fob which transmits it's data at switch on.If you don't have the correct key or a key without a keyfob then the anti-theft system will NOT be disabled and the car will not start. There is no easy answer for this as you need the correct keyfob or you need to purchase and have programmed, the new keys.. If this is not the issue, let me know and I will describe further procedures for your issues..
Anonymous
  • 593 Answers
  • Posted on Jan 26, 2010
SOURCE: 1996 Chevy silverado won't start when wet out
Start with a set of plug wires, since it seems to happen in the wet weather, and pick up a can of wd40 or wiredry to keep in the truck.Hope this helps.
Good luck.
3answers
2002 rav4 2.0; when engine is hot doesn't idle and give hard start: tps,GDI,egr,fuel pump,spark plugs and coil are all okay..when its cold first key the engine is fired up
Crank sensor , cam sensor , temp. sensor , Need to have a diagnostic scan tool hooked up ! one that can read engine sensor data !
Chevy engine wont start
Did they reverse polarity on you ? It's possible that they did just that, and when reconnected it, fried your electronics.
2006 chevy silverado cranks but wont start.
check the crank sensor that seems to cause intermittent starting stupidness. had that problem on my silverado.
1helpful
My brake lights stay on while driving my 2008 chevy 1500 Silverado any solution
I've seen lots of problems with brake switches on these style pickups. Usually they stick on. That also prevents you from being able to set your cruise control, because the engine computer sees that the brakes are on, when they're really not. If you have access to a scan tool that can read codes and data, there should be a Diagnostic Trouble Code stored in the engine computer related to the brake switch. You can also verify by looking at data in the scan tool that the switch is actually staying "applied", when it really should be "released".
If you don't have a scan tool, reach under the dash by the top of the brake pedal and unplug the brake switch. If your brake lights turn off (ignition key has to be on for brake lights to work), then you've found your problem.
I have a 1998 chevy silverado check engine code 1345a what does this mean
Do you mean Diagnostic Test Code (DTC) P1345 ?This DTC is a "Manufacturer Specific" code that is defined by GM as "Camshaft/Crankshaft Correlation Error".
It is basically telling you that your Cam/Crank timing is not within specifications.
Possible causes are:
> Improperly installed distributor assembly
> Badly worn distributor shaft or bushings
> Worn timing components (chain, gears, etc.)
Proper diagnosis is required to diagnose the actual condition that is causing this code. If any timing components are replaced, a scan tool capable of reading live computer data is required to check the cam/crank offset PID and make adjustments as necessary.
The specification for Cam/Crank offset is (Zero) 0 +/- 2 and must be checked with the engine running at 1500 RPM.
Trouble Code 12 on 1993 chevy silverado
code 12 indicates that your in diagnostic mode
1helpful
2002 Chevy Silverado, crank sensor installed. can't start truck.
After installing a new crank sensor, a Tech 2 will need to be hooked up in order to complete what is called a relearn procedure on the new crank sensor. Until this is done, your truck's ECM is unable to determine when cylinder #1 is at TDC and electronic timing is unable to be performed. Need to tow to GM dealership for this proceedure.
ABS brakes briefly release just before stopping sometimes
my advise to you is to take the car to a brake specialist as your brakes are the most important part of the car where no expence should be spared you may even save a life your own i am vert serious not being rude i assure you good luck Linds
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
