I guess I never set up the right date and time when I first started using the camera, and once I realized it, I correctly changed the date and time for future camera use. Now some of my pictures saved on my memory card have the coorect date and time, and some do not. How do I adjust the incorrect date and time on thos photos?
If you know how much wrong the clock was set, ie.
The clock was 1999-01-01 14:37 but it should have been 2017-05-22 19:00, there are softwares that could correct this error for a directory of files.
just search for exif time offset correct software (exif is the files hidden information about the photo)
SOURCE: sandisk memory card problem
Try using the sandisk with your computer to make sure the PC can read the card first of all. If that gives you an issue, the card could be bad.
SOURCE: Cybershot camera not reading the memory stick
Have you tried reformatting your memory card itself?
SOURCE: Date stamp on photo
You can download one of the utilities that is specifically meant to put dates on photos, such as DateMeNow:
http://www.ketara.ca/date-photos.html
The advantage is that you have a large number of configurable options, and that usually these utilities can process a number of photos with a single click, even for photos of different sizes.
SOURCE: Sony T3 cybershot screen black
http://esupport.sony.com/US/perl/select-system.pl?PRODTYPE=7&NAVDISP=di
SOURCE: photos saving to camera internal memory not to memory card.
go into memory on menu and choose change memory settings from internal to card
