Question about HP LaserJet M4345 MultiFunction Printer
Hp laserjet m4345 mfp printer not getting ready position
Hi all, i serviced my hp laserjet m4345mfp printer, after service swiched on, the printer not coming to ready position, i try many way like remove and replace fusr, formater board,cartridge, hard disk... but still its not come to ready.only hp logo only on disply. please help me to solve the problem. thank you.
Posted by bharathikumar... on
5 Related Answers
shadiabed
Shadi Abed
  • 72 Answers
SOURCE: HP LJ printer printing slowly
try to change the driver on the network definition
Posted on Jan 05, 2010
Lars-Eirik
  • 65 Answers
SOURCE: my hp laserjet m4345 mfp has all three lights
Try performing a cold reset. press and hold "6" while booting and counting RAM. Release when all 3 led's are lit. Use "3" and "9" and navigate to "Cold Reset". Press 6 to enter.
Posted on Jan 21, 2010
Anonymous
SOURCE: How do i refill my HP M1005 MFP Laser Printer toner cartridge?
if any softwere is have you for chaquing my cartage how many days are left to changing thel me
Posted on Oct 28, 2010
seeker5211
Seeker5211
  • 1089 Answers
SOURCE: Model HP LaserJet M4345 MFP The printer displays
You've done everything but replace the formatter.
Can you look at the Event Log? Look for a 79.xxxx error. That is definately a formatter.
Is this a solid error, meaning does it appear when printer inits?
Remove the DIMMs and flash memory and network cable. And reinstall one by one until error reappears.
Do you have another 4345 that you can "borrow" a formatter from?
Posted on Jan 12, 2011
puertobori
  • 7733 Answers
SOURCE: HP LaserJet M4345 MFP Printer
REINSTALL IS THE BEST SOLUTION.
If you need more help post back!
Thumbs and testimonial are welcome!
Posted on Jul 18, 2011
49.ff05 service error hp laserjet p5200
there is nothing wrong with your printer!! it is a connunication issue from the computer to the printer... cancel the document that you tried printing and try reprinting it again.. to clear the error remove the USB cable or Network cable then turn off the printer.. then back ON while the printer is in the ready state re attache the USB or Network cable and reprint the document :-)
I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
Jan 02, 2014 | HP LaserJet P3005d Printer
How to reattached output bin cable
How to remove the error reattached output bin HP m4345mfp
Feb 07, 2013 | HP LaserJet M4345 MultiFunction Printer
HP LJ M4345MFP printer message Downld file now SEND RFU UPGRADE ON USB DEV PORT
Better to replace the farmatter assm, chances are too low to recover the formatter.
Sep 28, 2011 | HP LaserJet 4345mfp Printer
Hp laserjet p2015dn prints one page and then goes offline. i delete the job, then turn printer off. Sometimes, it will show online and sometimes offline. Also, when I shut printer off the light may stop...
Known issue with these printers. The formatters fail at an alarming rate. At one point HP was replacing them under an Extended Service Advisory, but they have discontinued that program. You could try calling and raising a stink and they might do something for you. Otherwise, check on Ebay, likely someone is selling used formatters.
Mar 15, 2011 | HP LaserJet P2015dn Printer
How do i get this error cleared 49ff95 on hp laserjet m4345mfp
Hi, Well this problem could be due to a lot of things. If this won't with a power cycle then make sure there is nothing in the print queue, a corupt file could cause this. If nothing there then try a cold reset. I believe turn off then on when you see the memory start counting hold the number 6 down until the three lights turn on and stay on. (Something should be seen on the screen like disk intialize or something) push 9 until you see cold reset then hit 6 again.
Regards, polysandy
Apr 21, 2010 | HP LaserJet M4345 MultiFunction Printer
Have error code says 79 service(0142) Trap:00 Adr:0018D3F4
Turn off
Remove printer cable or
If it has a network card remove it
Turn printer back on
Let it come to Ready
turn off
re-install all cables / network card.
Jan 27, 2009 | HP LaserJet 5si Printer
Hi how to set up network scanner in m4345mfp all in one
Download and install everything you need including the instructuion booklet for the HP support website for yuo model . Link below:
http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=2512319&submit.y=7&submit.x=7&lang=en
Jan 06, 2009 | HP LaserJet M4345 MultiFunction Printer
Hp 2420 displays 53.07
The 53.07 error relates to Memory. Turn the printer off. Remove the right side cover. Remove any and all DIMM (memory) cards and printer/network cables from the formater board. The memory DIMMS are located behind the metal cover. Remove any Jetdirect Cards installed into the EIO slot on the back of the formatter.
With all accessories removed power up the printer and see of it comes to ready. If not, you need a formatter board. If it does come to ready, power it off and plug one peice that you removed back in and try again. Keep adding one at a time and powering up again until the error returns. When you get the error, the last added back onto the machine is the problem.
Here's a copy of the service manual to help with disassembly, troubleshooting and part numbers for ordering.
http://www.feedroller.com/Store/Service%20Manual/LaserJet%202410%202420%20and%202430%20SM.pdf
Hope that helps you. If so, hit me with a fixya!
Aug 19, 2008 | HP LaserJet 2420 Printer
HP LaserJet 1300 Printer - Won't feed paper
firistly try to find out the printer is ready or not then find out when we powearing on the printer then it is warming up or not if it is warning up and not come to ready position then open front cover pull the toner cartage and send back it propely
then give print if the problem is not solved then ckeck the printer cables and drivers
Jun 28, 2008 | HP LaserJet 1300 Printer
No paper pickup press
a solution was found to this at http://www.devincollier.com/2009/02/14/hp-laserjet-3050-no-paper-pickup-solution/
there is a spring that has become unsprung.
Article has pictures
Apr 22, 2008 | HP LaserJet 3050 All-In-One Printer
HP LaserJet M4345 MultiFunction Printer Logo
87 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
