Need to know how to fix broken immobiliser. fell apart
SOURCE: cigarette lighter
you will need to buy a new one. must have been one heck of a bump. make sure your plastic shroud isnt cracked whilst you have the lighter out.
SOURCE: broken immobiliser remote
usually there is a bypass switch somewhere under dash,or contact person or place that installed it
SOURCE: My drivers side window fell inside my door. Once I
O.K. getting the door off is a little tricky, Their is even a screw hid behind the little red reflector. You should be able to locate the rest. Once you get them out, the door pops off of those little white plugs in most new cars. After that you need to purchase a power window regulator. That is what broke that made your window fall in. It looks complicated, but it is only three or so bolts to change out. If you broke the window, Call around the salvage yards to try & locate a replacement. Don't forget to make sure you get one that has tinting if your was tinted.
SOURCE: column apart need to see
Please specify your car type & MY ! This procedure describes the disassembly of the steering wheel (Tilt) for a 1992 Chevy Lumina sedan. The purpose of this disassembly was to replace the RAKE. The rake moves the ignition switch mechanism when the key is turned. This system entails four major parts:
While this procedure describes the disassembly of the tilt steering wheel for a 1992 Chevy Lumina sedan specifically, most all GM tilt wheels are the same so this procedure will work on almost all GM products. Remember that these are general instructions. For more detailed instructions pertaining to your specific vehicle, consult the appropriate repair manual
As always, you should be very careful when removing the air bag module if your vehicle is equipped with one.
WARNING: The Diagnostic Energy Reserve Module or Sensing and Diagnostic Module (DERM/SDM) can maintain enough voltage to cause air bag deployment for up to two minutes after the ignition switch is turned off and the battery is disconnected. Servicing the SRS system during this period may result in accidental deployment and personal injury. Disabling the SIR System: Enabling the SIR System: Okay, let's get to work! First we need to remove the steering wheel.
Note: Information provide here is by an average "back yard mechanic" with minimal professional training. So any information is taken at your own risk. But maybe this will help. If you look in this area, Figure 9, there is a "V" cut out. Use a thin flat blade screwdriver. Insert about 2" and lightly pry down (handle of screwdriver up). This will release the safety tab and allow the column housing cover to be removed. Pay attention to the upper right hand screw mounting hole. This might catch while trying to remove the column housing cover. Lift off the column housing cover from the Right. While the column housing cover is free, the turn signal handle can be feed through it's cut out in the Housing by rotating the column housing cover 180 degrees to allow the washer tab on the handle to fit through.
Example:
1992 Chevy Lumina 3.1 Liter Tilt Steering Wheel Disassembly
Figure 1
1. Remove the steering wheel nut. Figure 2. (1)
2. Remove the spring clip with remover. Figure 2. (2)
3. Unplug the horn connector. Figure 2. (3)
4. Snap the horn cover off by pulling upwards. Figure 2. (4)
Figure 2
5. Remove the steering wheel with a steering wheel puller. Do not use a hammer to bang on the end of the shaft.
Figure 3
6. Push in and turn counterclockwise to remove horn wire. Figure 4. (1)
7. With the steering wheel removed, lift off the horn continuous connection mechanism and turn signal canceling arm. Figure 4. (2)
Figure 4
Removing The Column Housing Cover
Figure 5
To remove the turn signal handle, remove the screw indicated. Figure 5.
Figure 6
Remove the turn signal mounting top torx screw. Figure 6.
Figure 7
Remove the turn signal mounting bottom 2 torx screws. There is one more torx screw to the left of this one. Just below the turn signal handle screw. Figure 7.
Figure 8
Remove the hazard button mounting screw. Figure 8.
Figure 9.
Steering Column Component Diagram
SOURCE: my casing of the fob has broken on my 1996 corolla immobiliser. Where and what do I do to replace?
Contact the dealer, they can replace it. Make life more simple on yourself and just take it to the service counter at the dealership because they will need the numbers off of it.
