Question about HP OfficeJet V40 All-In-One InkJet Printer
My hp officejet v40 printer won't print the whole page. It only prints the first third. It says error. I tried to delete the printer so as to start fresh but I can't get it deleted. the messag
Posted by Sylvia on
5 Related Answers
Anonymous
  • 3587 Answers
SOURCE: my 1205 hp printer wont print because of an error in the queue
sure..you can do this by unhooking the printer, shutting it down, then turning on again..in meantime, you'll need to restart your computer too
Posted on Mar 10, 2008
Anonymous
SOURCE: Deskjet f2180 not printing complete jobs/will not delete...
Had a similar problem with an HP 1400 series printer. Check the HP support site. This link and the diagnostic utility work great for me:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&lang=en&custom_solutionid=rd_c01367104&rule=25494&product=458978&docname=c01072463
Posted on Mar 18, 2009
bob_computer
Project NOMAD
  • 3153 Answers
SOURCE: My Hp 1510 won't let me cancel a document in the queue
Microsoft has the help you need.
It is a common problem but the answer is here
You need to refer to method "D" about half way down the page
Once you clear the print job delete your extra printer installation
Hope that fixes you up
Posted on Aug 21, 2009
Anonymous
  • 33 Answers
SOURCE: priter job not deleted without pc rebooting in hp 1007
1st u try to off ur printer off then delete printing job
hope this is help full to u
Posted on Apr 08, 2010
Rider On Way
ONE-Touch-Solution
  • 1679 Answers
SOURCE: My HP Officejet 6210 All-in-One printer goes
HP Printers have common behavior of going into sleep mode if not used for a while. If this happens every-time the printer goes to sleep mode and you find printing issue, try this simple step below
Disconnect the power cable from back of printer
While holding the # and 3 button, connect the power cord to printer.
*Note this is partial reset and doing so you may loose fax logs and other fax related setting you have setup on printer.
Click the link below to know how to resolve the print job stuck in queue issue.
Link
Posted on Oct 23, 2010
Need help: our HP officejet v40 will not print.
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Feb 06, 2010 | HP OfficeJet V40 All-In-One InkJet Printer
Hp officejet v40. new cartridge but missing blue when printing
Sounds like your cyan print head is clogged. You can try to get it flowing yourself by rubbing the print head with a wet paper towel. If you press the print head on a dry paper towel you should see three distinct lines of color. If you still don't see the cyan, try letting the print head rest on the wet paper towel on a surface that ink can be cleaned up from or one you don't care about staining. If the cyan still won't flow, you should go back to where you purchased it and return it for a new one.
Jan 12, 2010 | HP OfficeJet V40 All-In-One InkJet Printer
Hp officejet v40
Try this ,see if from the printer menu you can find "clear all print jobs" and click ok.Somewhere in menu you'll find this.Good Luck ,you can also reset to factory defaults.
Sep 19, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
Press enter to align cartridges stays on and printer will not print. Print job goes to error.
KEEP A PAGE PRESS ENTER WILL PRINT AN ALIGNMENT SHEET SCAN THE PAGE AND THEN IT WILL WORK
Sep 18, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
How do i access the print cartidges on my hp officejet v40?
Below is a link to the Setup Guide. Click on it and see steps 12 and 13.
V40 Setup Guide
Dec 07, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
Printer prints partial page and then stops
We have had the same problem. I have found that if I close all windows not being used on the computer, then try to print the document again the entire document prints. This happens on an older computer we have that doesn't have alot of RAM.
Dec 04, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
Printer problem
Try changing the best working cable USB cable. and if same error occurs try on different PC, or laptop
May 09, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
HP OfficeJet V40 All-In-One InkJet Printer Logo
k24674
Mike
