Upgraded my Macbook Pro from Snow Leopard to Mountain Lion. I was using my Lacie as a backup drive successfully until I upgraded my operating system to Mountain Lion. Since loading Mountain Lion my Macbook Pro does not recognise my Lacie drive. Can you please help. I do not have the installation disk for the Lacie drive.
Here's a good start.
Plug your Lacie drive into someone else Mac or PC using MacDrive Pro and see if it shows up.
Posted on Dec 03, 2017
SOURCE: just upgraded to snow leopard and my samsung
If the printer is not connected and turned on when you upgrade the driver will not load, they slimmed down snow leopard by removing the drivers unless they are necessary. You should be able to either re-load or update with the printer connected and get the drivers.
Posted on Sep 17, 2009
SOURCE: I have an HP 5610 all in one printer which worked
Download and install the latest drivers from the HP Support site at
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=219&lc=en&dlc=en&cc=uk&lang=en&product=441125
Posted on Sep 30, 2009
SOURCE: I have upgraded my imac operating system to snow
I have been using my CanonScan LiDE 70 on the laptop. The laptop died. I am trying to use the scanner with another computer but have lost the original software disc that came with the scanner. The new computer (equipped with Vista) did an internet search and downloaded lide70vst641210ea14us. The scanner reacts when the computer powers up but nothing happens when I push the PDF button.
Can anyone help? Thanks
LT
Posted on Oct 27, 2009
SOURCE: Grey Screen Apple Start up issue
It appears there may be a possible startup item or issue with your firmware, which may be causing this issue, so I am going to provide some procedures in order to help you resolve this gray screen issue. But first, let me help you remove that disc first:
font.f1 {font: 13.0px Myriad Pro}
font.f2 {font: 14.0px Myriad Pro}
Procedure #1 - Ejecting CD from drive
Here are some steps I recommend you try to resolve the issue with the disc not ejecting properly
• Reboot your Mac
• Hold down your Mouse button(s) prior to the Apple Chime
• Keep holding the mouse button down while your Mac boots up
• The disc should eject before you reach your Desktop
• When it does, simply release your mouse buttons.
If this does not help resolve ejecting the disc in your Macbook's drive, you are going to have to take more of a command-line approach:
font.f1 {font: 12.0px Helvetica}
-EJECTING DISC USING TERMINAL-
From your Desktop:
•Click anywhere on a blank space on your desktop. Now you should see Finder listed near the Apple menu icon.
• From the Finder menu, click on Go, then Utilities from the
drop-down menu. This will take you to your Utilities folder.
• Locate and open the Terminal utility
• At prompt, type: drutil eject
• Now press the Return key on your keyboard
(NOTE: If you have a CD/DVD drive with a tray, type: drutil tray open press the Return key on your keyboard )en
• This command line should eject the disc from the drive, unless there are mechanical issues with the drive within your Macbook.
At this point the disc should be ejected from your Macbook. If this is the case, then I will now need to direct you back to Safe Boot mode, but with a little twist, from what you may have tried when you last when to Safe Mode:
I am going to have you take your Mac into Safe Mode to see if we can't remove a possible folder(s) that may be affecting your Mac's start up function.
Try these steps:
-SAFE BOOT MODE-
• Reboot your Mac
• Upon restarting your Mac, press the Shift key.
• Hold the Shift key until you see a White Screen with Gray Apple icon and eventually a spinning gear.
• When you see the Spinning gear, release the Shift key.
• Allow the Mac to continue booting up. Also this may take a little while.
(NOTE: this may take anywhere from 5 to 15 minutes to load to the Safe mode screen depending on the performance of your Mac, but if it exceeds this time, shutdown your Mac and try just once more. It may have just frozen up the first time around for you.)
• You are going to enter the Safe Mode (which looks like your main desktop environment the only difference is certain start up items are disabled.)
• Once within the Desktop in Safe Mode
• From the Finder Menu, click Go> Go to Folder
• Type in this line: /System/Library/StartupItems
• This path, is going to take you to the System Library folder which has all of your Mac OS X Startupitems.
• Remove all of those folders to the Trash.
*Reboot your Mac normally and see if you can access your normal User desktop environment.
Post back to me, if these particular Safeboot procedure does not help. Thanks!
Regards,
-Mactechtrainer
Posted on Feb 02, 2010
SOURCE: MP460 prints and copies but does not scan
Use Apple's "Image Capture" program, included with OS X. Also updating to the latest drivers may solve your problem, at least according to Canon. I haven't tested the latest drivers yet.
Posted on Apr 16, 2010
May 04, 2017 | The Computers & Internet
Apr 06, 2015 | Apple MacBook Pro Notebook
Jan 18, 2014 | Apple OS Computers & Internet
Oct 23, 2013 | Computers & Internet
Oct 16, 2012 | Apple OS X 10.8 Mountain Lion
Aug 19, 2012 | Lexicon I ONIX U42S 4x2 USB 2.0 DESKTOP...
Aug 14, 2012 | Canon PIXMA MP470 All-in-One Printer
Aug 01, 2012 | Apple OS X 10.8 Mountain Lion
Aug 24, 2010 | Lexmark Z600 InkJet Printer
Jul 09, 2010 | LaCie (300770) 250 GB Hard Drive
224 people viewed this question
Go to this site...Maybe it doesn't access with new operating system Mt Lion....common-https://www.lacie.com/
