We bought above enduro, having electrical charging problems. We replaced the battery and it still won't hold a charge. Battery is good, holds a load. Starter is okay. I drive it for 30 minutes, shut it off, won't start again, have to kick start. We can't find a service manual or wiring diagram for this. Any advice? Thank you, Ron
My yumbo had this problem as well. with the cover off on the side with the battery you will see what looks like a small amplifier with a white plug going into the top of it. i simply took mine off (1 bolt at the base of it) and cleaned it up especially the ground wire under the bolt you loosen. also try and clean up the plug and connections. before you start riding again give the battery a trickle charge with a 2amp 12v battery charger. if this doesn't do it try tracing the ground wire from the battery to the frame and make sure it is good and clean; you can also find another good spot on the frame to ground it. give it a shot and i hope it works out, j
Hi and welcome to FixYa,
Interesting, could not find any service information either. And have not had the chance to work on one.
In any case, your post "Any advice?", since battery is new, then there would only be 2 possibilities (aside from the fuse & wiring):
voltage regulator; and/or
stator windings.
The voltage regulator as the name implies regulate the voltage coming from the stator/alternator. It also converts the AC into DC to charge the battery and supply the electrical requirement of the bike when the engine is running. Most voltage regulators would look like the image below.
The stator windings are the coil inside where the magneto spins inside either. It is the alternator of the bike and produces the AC voltage that supplies the regulator. A stator would look like the image below. The red coil of copper wires.
Good luck and Thank you for using FixYa.
