Question about Microsoft Windows Vista Business Edition for PC
Problem with My Briefcase in Windows Vista
The function of My Briefcase in Windows Vista Business edition seems not to work. though i have managed to 'sync' to external HDD but i cannot open the folder in external HDD. heard that many users also have the same problem. i use XP in my personal laptop and the function works well. i love it. it is not so in Vista. how to solve this?
Posted by apiwatth on
  • Anonymous Apr 18, 2009
    brief case doesn't work in windows vista business.
    After copying unable to open briefcase
  • Anonymous Apr 27, 2009
    Files and fodlers that I save directly to the brief case do not update
Ken Davis
    New Friend:
  • 31 Answers
Hello, I thought Vista was retired some time ago through being a little unreliable. Now as far as Windows XP even though it was an old favorite there is no comparison in what it did and Windows 10, I have both a Surface Pro 4 tablet computer and a desktop both have Windows 10. I do wonder why people stay with even XP as it is not supported by Microsoft now and that in itself is a great risk. Thanks.
Posted on Nov 13, 2017
5 Related Answers
Anonymous
  • 326 Answers
SOURCE: In Vista What is actually stored in FileRepository?
If your system is slow, then use disk cleanup and defrag very often. The file repository is a collection of drivers for many different devices and programs.
Posted on Jun 02, 2008
pagebor
Rajkumar Bordoloi
  • 2785 Answers
SOURCE: Airtel-USB Modem driver for Windows Vista Business?
plz check the manufacture website for the drivers
Posted on Jul 01, 2008
Anonymous
  • 94 Answers
SOURCE: recover windows after virus attack
You need to stop the service from running before you go any further...
click start>run type in 'regedit' then navigate to
HKCU\Software\Microsoft\Windows\CurrentVersion\Run
Diable it from running. You can also do this by start>run type in 'gpedit.msc' and looking for the entry there, then disabling it
Once you have done that restart your machine, then look for every file on the HDD relating to ckvo.exe and deleting it. Check your %temp% folder and registry as well. When you think you have all the files empty the recycle bin, delete the key from the registry and restart the pc again.
Check to see if you can access you HDD as normal.
I cannot say for sure if this works, but it it is worth a try.
Do a google search for Malwarebytes' Anti-Malware, there is a free version available, I believe Cnet Downloads have it on their site, install and update then run it, there is a good chance that the program will pick up the virus and remove it for you.
Posted on Aug 11, 2008
Anonymous
SOURCE: Windows vista starter themes
Just load all your downloads into your computer,then right click on the desktop then press tab key written themes then click the theme you want to use.then it will change automatic.
Posted on Aug 19, 2008
gambit3rogue
gambit3rogue
  • 106 Answers
SOURCE: want to install xp instead of vista - but end up in caldera dr dos
Alot of the reason is because they don't want you to down grade from Vista to XP. But see if this helps. Start your pc, insert XP disk, as soon as the screen comes up press f12 which will allow you to choose the booting sequence, click CD- ROM and the disk should start to be read. understand this tho by downgrading you will have a hard time finding the appropiate drivers for most of your devises since they were meant to be runned by Vista. Here's a tip go find the drivers in europe (be it toshiba.europe, Dell.europe) for they are still running XP. to find the drivers for your particu;ar pc just find the series number and the last unit to run with xp and viola a working xp on a vista pc. Hope this helped
Good Luck =)
Posted on May 30, 2009
How to Make a Brief Case on Windows?
follow this steps
  1. Copy the briefcase over to the second drive. You can do this in a multitude of ways, the simplest of which involves dragging the briefcase into the Windows Explorer window of the drive you want to sync to.
  2. Go to another computer and edit any of the files in the briefcase.
  3. When you are back at the computer you created the briefcase on, right-click the briefcase while viewing the second drive in a window and click "Update All". This will sync any of the changes you have made to the files with the computer.
Oct 20, 2016 | Computers & Internet
System requirements of vista
For Vista Home Basic >>>
  • 1 GHz 32-bit (x86) or 64-bit (x64) processor
  • 512 MB of system memory
  • 20 GB hard drive with at least 15 GB of available space
  • Support for DirectX 9 graphics and 32 MB of graphics memory
  • DVD-ROM drive
  • Audio Output
  • Internet access (fees may apply)
Additional requirements Actual requirements and product functionality may vary based on your system configuration. Windows Vista Upgrade Advisor can help you determine which features and edition of Windows Vista will run on your computer.
While all editions of Windows Vista can support multiple core CPUs, only Windows Vista Business, Ultimate, and Enterprise can support dual processors.
For Vista Home Premium, Business and Ultimate >>>>>>
  • 1 GB of system memory
  • 40 GB hard drive with at least 15 GB of available space
  • Support for DirectX 9 graphics with:
    • WDDM Driver
    • 128 MB of graphics memory (minimum)
    • Pixel Shader 2.0 in hardware
    • 32 bits per pixel
  • DVD-ROM drive
  • Audio Output
Home Premium / UltimateTV tuner card required for TV functionality (compatible remote control optional).
Home Premium / Business / UltimateWindows Tablet and Touch Technology requires a Tablet PC or a touch screen.
UltimateWindows BitLocker Drive Encryption requires a USB Flash Drive and a system with a TPM 1.2 chip.
Windows Vista minimum supported system requirements Home Basic / Home Premium / Business / Ultimate
  • 800 MHz processor and 512 MB of system memory
  • Support for Super VGA graphics
  • CD-ROM drive
Regards.
Sep 21, 2009 | Microsoft Windows Vista Ultimate Edition
Drjve hp1012 for windows vista basines
At this moment there is no Vista driver for this printer.
You may download the current XP driver from HP to provide printing functionality. Windows Vista printing is very similar to Windows XP and most print drivers supported in XP environment for LaserJet printers may also work in the Windows Vista operating system.
Aug 04, 2009 | Microsoft Windows Vista Business Edition...
Scanner won't work with windows vista
Option one: Scan using Windows Fax and Scan
  1. Click the Windows icon (c01319360.gif ), click Programs , and then click Windows Fax and Scan .
    NOTE: The Windows Fax and Scan option is available in the Business, Ultimate, and Enterprise editions of Windows Vista. If you have the Home Basic or Home Premium edition of Windows Vista, skip to Option two: Scan using Paint .
  2. Click New scan .
  3. Click File , and then click Scan .
  1. Click the Windows icon (c01319360.gif ), click Programs , and then click Accessories .
  2. Click Paint .
  3. Click File , and then click From Scanner or Camera .
  4. Click Scan .
Jul 01, 2009 | HP Officejet 5610 All-In-One InkJet...
Using briefcase in vista
It is not uncommon for vista to take an inordinate amount of time to open the briefcase, but there are some steps you can take to ensure the process is smoother. Please have a look at this link. maybe this one too.
You could try run as with UAC turned off, and see if that's the issue. link here. and here. and the definitive scope here.You may just not have permission.
Have you tried creating a briefcase from within vista and moving it to the xp system instead?
Are you otherwise able to access data on the flash drive? If not, look for driver updates from the manufacturer to make it compatible with vista.
Finally, have a look at the event viewer &/or device manager and make sure there are no error codes associated with the drive that are preventing access, or see what error id is associated with the explorer hang. If you get a code, report back and we'll be happy to look into it.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 19, 2009 | Microsoft Windows Vista Business Edition...
Error message at start up
This is a toolbar error. If you have added toolbars yahoo, shopping, news, google, etc.... It can cause it. So can viruses. AskBar seems to be the most common to cause the error search and see if you have it C:\Program Files\AskBarDis you can also go to in IE Explorer (your internet) Programs, Manage Add Ons, and disable anything not signed or that you think maybe a virus. Anything from Sun, Microsoft, or Adobe just leave alone they are fine.
Apr 28, 2009 | Microsoft Windows Vista Business Edition...
Are they the same - windows vista 32 bit platform edition and windows vista home basic 32 bit sp1
Yes and no. Think of 'platform' as a general header when looking at operating architectures (there are different types) and Vista choices.
Vista choices under the 'platform' 32-bit are:
• Windows Vista Home Basic 32-bit
• Windows Vista Home Premium 32-bit
• Windows Vista Ultimate 32-bit
• Windows Vista Business 32-bit
• Windows Vista Enterprise 32-bit
Another example of the "64-bit platform" and Vista choices are:
• Windows Vista Home Basic 64-bit Edition
• Windows Vista Home Premium 64-bit Edition
• Windows Vista Ultimate 64-bit Edition
• Windows Vista Business 64-bit Edition
• Windows Vista Enterprise 64-bit Edition
Mar 05, 2009 | Dell Computers & Internet
Burner does not finalize discs
Microsoft has confirmed that this is a problem in the Microsoft products that are listed in the "Applies to" section.
APPLIES TO
  • Windows Vista Starter
After you install Windows Vista on a computer that uses an SiI Parallel Advanced Technology Attachment (PATA) chip from Silicon Image, the computer does not recognize an attached optical drive as a drive that supports recording. Therefore, you cannot use the computer to burn CDs or DVDs.
This problem occurs because the SCSIport driver does not populate the correct number of bytes for an IOCTL_STORAGE_QUERY_PROPERTY Request Packet (IRP) when the device does not return a correct serial number.
Service pack information loadTOCNode(2, 'resolution'); To resolve this problem, obtain the latest service pack for Windows Vista or download the following Hotfix.
Microsoft Hotfix http://www.microsoft.com/downloads/details.aspx?FamilyId=2E692102-D483-44B0-BBFF-FA87AE019CBE&displaylang=en
Please rate this a fixya
Feb 01, 2009 | Microsoft Windows Media Player
Hp dv7-1132nr Quickplay touch button doesn't launch quickplay.
Hallow Dear,
Please use this link to download Drivers for your PC (20M)
XP/Vista - ftp://ftp.hp.com/pub/softpaq/sp38501-39000/sp38688.exe
Operating Systems
Microsoft Windows 2000
Microsoft Windows XP Home Edition
Microsoft Windows XP Media Center Edition
Microsoft Windows XP Professional
Microsoft Windows XP Tablet PC Edition
Microsoft Windows Vista Enterprise 32 Edition
Microsoft Windows Vista Home Basic 32 Edition
Microsoft Windows Vista Home Premium 32 Edition
Microsoft Windows Vista Business 32 Edition
Microsoft Windows Vista Starter 32 Edition
Microsoft Windows Vista Ultimate 32 Edition
Microsoft Windows Vista Enterprise 64 Edition
Microsoft Windows Vista Home Basic 64 Edition
Microsoft Windows Vista Home Premium 64 Edition
Microsoft Windows Vista Business 64 Edition
Microsoft Windows Vista Ultimate 64 Edition
This Will Completely Solve your Prob; if there is no any internal Hardware Problems with Quick Lunch Buttons
(I feel there is no any coz u mention about Ding Sound. That mean your system is recognizing your key input & all you need is Just program those keys – above setup will do that)
** If you didn’t solve your prob; my advice is take your lap to a good technician with component level Repair skills.
Thank you & Best Regards
Dinu….
Dec 20, 2008 | HP Pavilion dv4000 Notebook
Microsoft Office 2003 Professional - Picture manager
Fixed the problem - Even though the pc checks for updates automatically I should have checked to see if there were any available updates at the microsoft website. There were 3 available and once downloaded and installed the picture manager part of office suite professional 2003 is now working just fine!
Sep 19, 2008 | Microsoft Office 2003 Basic Edition...
Microsoft Windows Vista Business Edition for PC Logo
622 people viewed this question
Top Microsoft Computers & Internet Experts
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
ThaMp3Doctor
ThaMp3Doctor
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
