This is our third year with this furnace/thermostat combo. This year, the furnace will not kick on more than once. Error code on furnace said it was a limiter problem. We have replaced that and cleaned out duct work. The furnace will kick on and run great until themp is up. It will start to fire up to run again later but shuts itself off instead of running.
SOURCE: Hunter Thermostat fan won't turn off
Hi and welcome to FixYa,
Initially, I am inclined to suspect 3 possibilities:
Good luck and Thank you for using FixYa.
SOURCE: Hunter 44260 Thermostat Problem
make sure you have the jumper in place
if you dont have a secondary heat source red should be on r with a jumper to rh
SOURCE: the furnace wont turn on even though it says it is
not all digital thermostats are compatible with the manufacturers circuit control boards in the furnace. Hunter has had this problem several years ago. Other than that you may have miss wired the unit. usually the furnace is used as backup heat (during defrost) or emergency heat if your heat pump konks out. Are you switching to emergency heat for a furnace call?
SOURCE: I have a hunter 44260
probably the temperature in the area where the thermostat sensor is placed is hotter ...so .if you want a higher temperature ..just set it with 5 degrees higher..and see what 's happening ..I think this will make it get to 70 ..
