Question about Amana 25.8 cu. ft. Side-by-Side Freestanding Refrigerator SRD26VP
My Amana SRD2555w won't freeze food, fridge side is ok. Is it possible for it to be stuck in Defrost mode?
We've had it unplugged for some time, but I'd like to put it back into use. It has an Ice Maker. I verified the correct Temp control setting. Door seals are OK. The only other problem we had with it is the Ice selection switch on the door front is faulty, so you have to get it between crushed and cube to stop it from delivering ice through the shoot
5 Related Answers
Anonymous
SOURCE: amana side by side ice dispenser leaking water
icemaker wont dump ice
Posted on Jun 19, 2008
fixrguy
  • 415 Answers
SOURCE: 1. I am getting black spots in the ice cubes.
multiple probems you have my friend the black in the cubes is the telfon coating on the mold of the imkr and the best thing to do is replace the complete icemaker then this will solve the leak issue as well the mold is cracked and for the some how the 1/4'' tube has sprung a leak pull away from wall take off the back panel and have some one try to get water from the dispenser then you find the leak then its off to the menards to buy a plastic 1/4'' push connector about 5.00 once you got the coupling shut off the water to the tube that goes to the frig once done use a razor to cut the bad part of the tube (don't use sissors or ****to cut tube it will squeeze the tube and not allow it to seal properly in you new coupler you just bought) then after you cut off the bad part out just push into the coupler it will go in to the coupler about 1/4'' into the coupler install the other side turn water back on and test again...... congrat's you fix it but your not done unplug the frig get your vacuum and clean the dust bunnies out of the rear of the unit once done plug back in and make sure you see the fan blade turn freely and nothing is holding it up did it turn ............. ok then put back on and push the frig back to the wall allow at least 2'' away from the wall
Posted on Sep 06, 2009
John Hall
  • 1218 Answers
SOURCE: Ice maker stopped working
Good day,
A step by step procedure should resolve your problem. If the dispenser is working, you can skip that step.
First step is to take a small paper cup of water and fill the cavity until it is near full. With the ice maker turned on, close freezer door and wait 3 hours to see if it harvests. If not, the ice maker is bad, and must be replaced. If the cubes harvest then.......
Three possibilities.
1. The water supply from the house is not delivering water to the water valve. Shut off the house at the meter, disconnect the line going to the water valve, and with the line pointed into a bucket, have someone turn the valve back on for a 15 second count. The water should come out smartly. If not, the line and it's fittings will have to be replaced.
2. The fill tube from the back of the machine that feeds water into the back of the ice maker is frozen up. You will have to remove the ice maker to visually inspect that tube. If blocked, it needs to be defrosted, but use caution. Too much heat too fast will start to melt plastic and vinyl parts you don't want melted.
If this is the case, then once cleaned out, you will have to change the water valve located in the back bottom rear of the machine because it is leaking during the off cycle.
3. If everything checks O.K. up to this point, you will have to purchase and install a new water valve, and install it.
P.S. Under very rare occasions the electric circuity in the ice maker will fail to send a signal to the water valve. Although rare, it can happen, in which case the best option is to replace the ice maker and water valve.
Posted on May 25, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: Amana bottom Freezer with top refrigerator - Ice
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Posted on Jul 13, 2010
muffteck
Frank England
  • 202 Answers
SOURCE: Amana Refrigerator ARS9167AB Ice Crush does not produce ice at all.
either the switch is bad that moves the selection from crushed to whole ice or the ice crushing motor is out
Posted on Sep 16, 2010
AMANA SIDE BY SIDE refrigerator/freezer . Freezer freezes intermitently, and then stuff thaws. Cleaned the botton coils, didn't help. unplugged and re-booted. didn't help
HI.intermitent faults r allways abit problematic .but run through some basics ok?1-after defrosted freezer works ok?2-how long for.if ok then all u can do is change defrost timer and t/stat one at the time or together.clean condensig unit thoroughly.good luck.ali
Jul 05, 2012 | Amana Refrigerators
Amana BB20VE - Food Freezing in Crisper
Have you checked it's not in fast freeze mode, and that the setting on the thermostat is about in the middle?
Apr 18, 2012 | Amana Refrigerators
Amana fridge (mod #sxd22s2) is freezing foods on bottom level- dial turned to lowest setting & temp. is 28 to 32 degs.at bottom of fridge.
seeing that 32 is freezing point of water,its not suprising that food is freezing.it should be 38f or +3c.when was the last time you did a FULL defrost(NO HAIRDRYERS PLEASE).ALSO CHECK DOOR SEALS ARE TIGHT ALL ROUND.
Nov 27, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Refigerator is freezing the food at all settings
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 28, 2010 | Amana ASD2626HE Side by Side Refrigerator
Amana #srd2555w bought from a friend in working condition. 3 yrs old brought home on its side. vacumed coils working 3 days then stopped cooling in fridge followed by ice build up and not working in...
You have a defrost problem. 3 parts: Timer (or "adaptive defrost control"), defrost heater and def. termination thermostat.Find the timer, it shoud be nehind the bottom front grille to the right on Amana (if you see a blck box under there with a sticker on it, it's the ADC model) turn the timer CW until it clicks. Take the back off the bottom of the freezer and listen. After 5-10 minutes if you hear the sound of the sound of water hitting a hot grill. If you hear this the heater and thermo are working and the problem is the timer/ADC. No hiss? Unplug fridge. Check thermo and heater for continuity. Replace the one that's open. If the heater's open, replace the thermo too: Maybe it didn't open soon emouhg and caused heater failure.
Sep 25, 2009 | Amana SXD524VW Side by Side Refrigerator
Refrigerator is freezing everything top to bottom wondering if there is an air filter that I could clean as we have had some drywall done recently and thought maybe something is restricting air flow.
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water dispenser keeps running
Apr 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer side works fridge side doesnt
    click on the required option.
Feb 20, 2009 | Kenmore Refrigerators
Icemaker is not freezing ice, freezer not freezing food,
The ice maker won't work if the freezer is warmer than 17 degrees so that's not an issue till you get the freezer cold again. I would guess that your unit is stuck in the defrost cycle. This could be the defrost timer failing. See if you can find the defrost timer in your unit and advance it by hand if possible. http://www.partselect.com/PartSearchResults.aspx?modelnum=jcd2295hes&mfgmodelnum=&fkmfgid=1&hint=defrost
Dec 01, 2006 | Jenn-Air JCD2295HES Side by Side...
Refrigerators Logo
Top Amana Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
