Two wires coming out of bottom rear of motor are blue with white and green with white. 6 wires right above that (going to stator?) 3 wires on side of plug are:Dark Blue with Red, Red with Pink(?), and Green with Red Other side are: Dark Green with Black, Yellow with Red, and solid Pink Been threw 3 wire harnesses purchased on-line and not one dealer in Minnesota or Wisconsin.
SOURCE: need a stereo wiring diagram for my van.
Yep!
Here you go...
1995 Mercury Villager Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Green/Purple
Radio Ignition Switched 12V+ Wire: Yellow/Black
Radio Ground Wire: Black/Light Green
Radio Illumination Wire: Green
Radio Dimmer Wire: N/A
Radio Antenna Trigger Wire: N/A
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 5′ x 7′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Light Green
Right Front Speaker Wire (-): Dark Green/Orange
Rear Speakers Size: 5′ x 7′
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Light Brown/White
Left Rear Speaker Wire (-): Light Brown/Yellow
Right Rear Speaker Wire (+): Light Brown/Green
Right Rear Speaker Wire (-): Brown/Pink
That's what they show for factory
K
Check the dealer to see if they have a pig tail to wire in. if so the new pigtail should have same wire color for matching up.
WIRING INFORMATION 2001 Subaru Legacy
WIREWIRE COLOR LOCATION
12V CONSTANT WIRE WHITE Ignition Harness
12V IGNITION WIRE GREEN Ignition Harness
12V ACCESSORY WIRE YELLOW Ignition Harness
STARTER WIRE WHITE/BLACK Ignition Harness
POWER DOOR LOCK (-) WHITE Harness In Driver's Kick Panel
POWER DOOR UNLOCK (-) GREEN/RED Harness In Driver's Kick Panel
PARKING LIGHTS (+) ORANGE At Light Switch
DOOR TRIGGER (-) PINK/BLACK In White Connector Behind Fuse Box
TRUNK TRIGGER (-) YELLOW/BLUE In White Connector Behind Fuse Box
TRUNK RELEASE (5-wire) LT.GREEN/YELLOW At Motor In Tail Gate
FACTORY ALARM ARM (-) Factory remote only
FACTORY ALARM DISARM (-) Factory remote only
TACHOMETER YELLOW/GREEN At Ignition Coil
BRAKE WIRE (+) WHITE/BLACK At Brake Pedal Switch
HORN TRIGGER (-) RED/GREEN Harness At Steering Column
LEFT FRONT WINDOW UP BLUE/RED At Driver Window Motor Inside Door
LEFT FRONT WINDOW DOWN BLUE At Driver Window Motor Inside Door
RIGHT FRONT WINDOW UP BLUE/RED Harness In Driver's Kick From Driver Door
RIGHT FRONT WINDOW DOWN BLUE Harness In Driver's Kick From Driver Door
LEFT REAR WINDOW UP BLUE/RED Harness In Driver's Kick From Driver Door
LEFT REAR WINDOW DOWN BLUE Harness In Driver's Kick From Driver Door
RIGHT REAR WINDOW UP BLUE/RED Harness In Driver's Kick From Driver Door
RIGHT REAR WINDOW DOWN BLUE Harness In Driver's Kick From Driver Door
We need to know what wiring harnesses for what motor
Sorry I'm a newbie!! The wiring is from a 2007 ATV Eagle Lyda 203e(not sure what model) 4 stroke, liquid cooled. Here's where it gets fun... Egl Motor 171 fmm/2 cylinder
