Basically my monitor is not displaying anything and everytime i try to turn it on it says no signal also i tried d-sub and dvi and this happened to me last time and and i put the cd that came with the monitor on the cd drive and it maggically apearred well this time i had no luck any help would be appreciated
Connected to what, NO sign.
using what video port,? VGA?
in the F22 mon.
push menu button (mon just turned on)
and push monitor reset.
and in , input port scan ,turn off AUTO and set it manually to VGA.
NO PC told
test the PC on other good monitor yet? see if PC is dead
no signal means, (and never lies)
page 14 reset see it.
https://www.manualslib.com/manual/204760/Aoc-F22s.html?page=14&term=default&selected=3#manual
SOURCE: AOC LM729 17" LCD Monitor Screen goes black
YOU HAVE A DRY SOLDER PROBLEM, You have to open the monitor and check the solders in the PC BOARD , mainly where theres A SMALL transformer resolder it , and try again ,that should fix it . hope it helps
SOURCE: aoc lm725 display off after few seconds
I've had a very similar issue on many Dell Monitors. Mine have been under warranty and they usually send me a new monitor, but I believe the issue lies with the power supply within the monitor.
SOURCE: On Screen Display (menu) is Locked
Hi there - I read in another forum to use the left button instead of menu. Give it a try - power off and hold left button while powering on.
I'll cross my fingers for you :)
SOURCE: AOC 1" - Monitor Says "no signal"
Sounds like a connection problem. Make sure BOTH plugs are securely located. Ian.
SOURCE: AOC F22 lcd 22
Hold down the power button to turn it off, then hit the power button and immediately hold down the left side of the ring. Wait for the OK to disappear.
Took me a couple tries, but it works.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
