Question about Dishwashers
Kenmore altra wash dishwasher, no water
Yesturday it worked fine, today no water is filing dishwasher. It seams like a computer/memory issue. Water drains out fine, when I our our water into it. Dishwasher is connected to water under the sink and that has been working fine. When you start a cycle you hear the motor/noise but nothing is happening. A couple minutes later it stops and the start button starts flashing. The spinner/sprayers are not even turning.
Any advice of how to get it working again.
Posted by j9_rem on
  • jjsexton919 Mar 18, 2009
    I turn in the diswasher and it seems as though it is starting up, but no water comes out of the sprayers. It drains fine.
okcchemist
    Problem Solver:
  • 17 Answers
Check the water inlet solenoid and the float.
Posted on Jun 02, 2017
5 Related Answers
DENNIS MITCHELL
  • 1003 Answers
SOURCE: Kenmore 587 High Temp/Heat Dry lights flashing, cycle not complete
REPLACE TIMER
Posted on Jan 18, 2008
Anonymous
SOURCE: loud noise
Very loud squeaking sound, at the start of each cycle.
Posted on Jan 22, 2008
bdic
SOURCE: maytag jet clean dishwasher model# dwc7400aaw
Water is leaking under the bottom?
Posted on Feb 03, 2008
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Posted on Mar 22, 2008
Anonymous
SOURCE: Kenmore Dishwasher does not wash
my problem is the motor hummms for a minute or so and turns off. Could this be the capacitor? how do you test a capacitor?
herb
Posted on Jul 14, 2008
Kenmore Elite dishwasher won't clean and leaves white film
CHANCES ARE YOUR WATER TEMP IS TOO COOL and the 2nd
PROBLEM IS VERY HARD WATER THAT IS CAUSING THE WHITE RESIDUE. RAISE THE TEMP ON HOUSEHOLD WATER TO 140 F AND ADD SOME SALT TO THE WASH CYCLE. LASTLY USE A LIQUID DETERGENT LIKE LIQUID CASCADE.
I have a Kenmore Ultra Wash Dishwasher model# 15867990. The Sani Rinse light stays on and when you press another button the lock on button comes on and then the dishwasher will not start. I have tried...
Hi
It may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
2helpful
665-110733490 Was working fine ,last night shut it off w/water in the bottom.also pushed cancel/drain did not drain.today I ran A wash cycle but after wash still had same amount water in...
Hello & Welcome to FixYa
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose-filter assembly or the drain pump not working. First try to clean the drain hose and drain pump filter located inside the front bottom panel for any clogs, then check drain pump operation. Take off the bottom access panel to clean the drain pump filter and hose. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
1helpful
My Kenmore ultra wash 6651736 dishwasher broke almost to the month it turned 6 years old and I'm trying to decide if I should fix it or buy new.It washed wonderfully up to the day it stopped .the water...
very common issue on these units, the motor had failed, the motor did have a five yer warranty but we are beyond that.
You can purchase the part from the link below,
http://www.appliancerepairlesson.com/
Kenmore Dishwasher model 665-13743k601 The clean light is flashing and will not reset. The dishwasher will not run.
Hi
If clean light is blinking 7 times then it may be an issue with heater circuit, door switch or wash pump. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset.
If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back for further assistance.
Kenmore elite not washing dishes
Sounds like the motor is stuck. If your careful you can unplug the dishwasher or turn the breaker off, take the bottom panel off and reach in with your finger and spin the motor assembly.
Nov 12, 2009 • Dishwashers
Dishwasher not working again
is the clean light blinking, if so make sure water temp is at least 120 degrees
Water at the bottom
check the sump screens inside the tank make sure their clear,also check the wash arm holes for obstructions,check the seams of the arms for cracks
No hot water when washing dishes
sounds like it was hooked up to a coldwater line instead of a hot and your heating element in the dishwasher went bad from overload or your pc board went bad but i would check to see if it is hooked up to hot water line first..
Dishwashers Logo
Top Dishwashers Experts
Oloyede Monsuru
