Question about M-Audio Ozone USB Audio / MIDI Mobile Workstation Sound Card
Fruity loops tone to record in adobe audition 1.5
Iam having creative audigy pro sound card for my adobe audition 1.5,using windows xp,i want to use fruity loops organ voice and all the tones in it with midi but i cannot record the tone,sometimes it is recording but platback also recorded,how to solve this problem,
will protools m powered audio recording software will work with creative audigy sound card,
with regards,
David Franklin
Posted by davidfrankli on
5 Related Answers
XboxModifier
Steve Martyn
  • 123 Answers
SOURCE: midisport 4x4 delay problem
Hello Nelson,
What are the specifications of your mace and what is your studio set-up
Have you lookied at performance monitor to see what process is using up all the memory?
If sound like you may have to tweak your machine to suit your specific needs.
I too had similiar problems and tuned my machine to to work more effeciantly...
Posted on Feb 20, 2008
John Bolton
  • 87 Answers
SOURCE: hearing double voice when monitoring through delta 1010
Check to see if you have your onboard sound turned on. If you do turn it off and this should stop the double voice.
Posted on Jan 08, 2009
Geekman
Chris Hingee
  • 32281 Answers
SOURCE: Windows XP SP3 platform with single Delta 66.
Go to Device Manager and enable the audio card.
If you cannot enable the audio card or it is not working then install the audio driver again.
Posted on Mar 30, 2010
Testimonial: "Thanks for the quick response and good info, it was very helpful."
Anonymous
SOURCE: Gaps and noises in my Session recording
Is it bus powered? If it is only plugged into the USB port and not also into the AC outlet, it may be because your USB port does not supply enough voltage or enough current. USB is spec'd at 5V, 500mA, but many fall short. I have the same problem with a Tascam US-122. I haven't tested yet, because it doesnt have an external power port. I would need to splice 5V power into the USB cable.
Posted on Jun 10, 2010
ginko
Ginko
  • 19396 Answers
SOURCE: I have newly bought a
Hi.
Try closing down Propellerhead software. Go to sound settings in control panel, and check what is the preferred audio device in Vista settings. You should get a dialog box similar to the one below, with the 2626 detected as high definition audio device.
If still no luck, try updating Vista. There is a Microsoft update that may be needed to reognise high definition audio device.
See: No output audio device installed - the Fix - Microsoft Windows
Download details: Windows Vista (KB929685)
Alternative download (try microsoft first):
Download Windows6.0-KB929685-x86.msu
If that does not work, then there is another update that may be needed. See:
Download details: Windows Vista (KB937077)
Restart the computer after each update.
Regards.
Ginko.
Posted on Nov 15, 2010
Is there a free option to fruity loops?
The only real factor that comes near to Fruity Loops for Mac that is free is Auadicity. If something a little more advanced is wanted by you check out Adobe Audition or Professional Tools.
Audacity is free, open source software for editing and saving sounds.
Dec 31, 2012 | Music
I want sb0220 sound driver
http://download.cnet.com/creative-labs-sound-blaster/3000-2120_4-10022925.html
This is the latest driver update for the Sound Blaster Live! series of audio cards only for users running Windows 95 and 98. This release includes updated version of Surround Mixer 1.0 and AudioHQ, 1024-voice software MIDI synth for Sound Blaster Live! (Option to select up to 1024 software voices), and improved support for Occlusion and Obstruction effects in EAX2.0
http://download.cnet.com/creative-labs-sound-blaster/3000-2120_4-10005159.html
If you're using Windows 95/98, you can download this file and update your Sound Blaster 16, Sound Blaster 32, and Sound Blaster AWE drivers. Please refer to the readme file for installation instructions. This new version solves the audio distortion problem that occurred when the Sound Blaster 16Xpress chip was left running overnight.
http://download.cnet.com/sound-blaster-pci128-drivers/3000-2120_4-10038063.html This is an updated driver release for Creative Sound Blaster PCI128 for Windows NT only
http://download.cnet.com/sound-blaster-audigy-driverpack/3000-2120_4-10198813.html The driver contains optimized support for Windows 2000/XP operating systems and is designed for use with all current models of Sound Blaster Audigy audio cards (all existing Sound Blaster Audigy Card to SB023x models). Features includes: drivers are WHQL Certified; provides Dolby Digital decoding from external SPDIF Input; speaker settings in Creative Audio Mixer are synchronized with Windows Multimedia setting; new presets and effects added.
http://download.cnet.com/creative-sound-blaster-audigy/3000-2120_4-10198811.htmln This update is for all Audigy 2 and Audigy 2 ZS series audio cards, which include the Platinum, Platinum eX, Platinum Pro, Digital Audio and Gamer versions. This update is not meant for original Audigy series audio cards. This update contains additional features and fixes to improve the performance of your Creative Sound Blaster Audigy 2 or Audigy 2 ZS series audio card.
on cnet download.com you can find these drivers hope one of these will help
Jun 12, 2011 | Creative Labs Creative Sound Blaster Live...
I am using Adobe audition 1.5 for recording my songs.. now.. i am facing big problem while using that software.. there is multitrack option available in that software. we have put karaoke track in one...
Welcome to FixYa!
I assume that you know your way around adobe audition 1.5 because I'm currently using adobe audition 3 on windows 7. The menus are different, but I'm going to give a few points that might help.
Windows Sound/Volume:
Make sure that the sound card you are using is selected, specially if you are using an additional external USB sound card (which is much better). Disable other sound cards, if any.
Adobe Audition:
One of the pull down menus located on the upper part, it has an option that says "Device Properties" or anything like that. This is where you set the input signal will be coming from and likewise the output signal.
The input signal should be the input of the sound card you selected in windows. Same goes for the output signal.
On multi-track view, check the track to be recorded. Make sure that the input is from the input of the sound card and not from anything else. The button for the setting is somewhere near the Solo/Mute/Record buttons.
If this will be set correctly, you will be able to play the song on the 1st track and record ONLY your voice on the 2nd track.
Keep me posted.
Thanks for using FixYa.
Jas247
Apr 09, 2011 | Adobe Audition 1.5
I have a tower computer kind of older . when i plug in the microphone to the back i.e. microphone port, nothing happens to signal it reads the microphone and when i try to use the microphone for fruity...
Assuming you are running windows XP you need to
1. right click the speaker in the lower right corner and select adjust audio properties.
2. Select the audio tab
3. Pull the drop down menu under sound recording and make sure it is selected to your audio driver device. Most are either soundmax, creative(for soundblaster and audigy standalone cards), realtek, or ASUS.
4. Next repeat step one but select open volume control
5. Go to options and then properties
6. Select the circle for recording and make sure your mic input is checked.
7. Close that window and recording mixers will pop up. Select the input you need by checking the box in the lower left corner of the mixer channel. Adjust the level and then use your recording program or sound recorder under Program files>accesories>communication>sound recorder.
Mar 08, 2011 | Philips Phillips...
Crackley bubbly sound
  1. What version of Windows?
  2. What hardware?
My initial guess is distortion.  With some hardware, and at least on Vista, I had really bad pops/cracks with Audition 3 initially using a Creative Labs Audigy 2... sound card.  Then after getting an M-Audio Delta 1010LT, no more problems EVER.
Aug 13, 2008 | Adobe Audition 1.5
Direct sound is not supported....
Follow these steps (Windows Vista):
Control Panel - Hardware and Sound - Sound - Manage Audio Devices - Record - Right click to show all the devices (including the deactivated ones) - Activate all the devices you can.
In Adobe Audition:
Edit - Audio Hardware Setup - Edit View - Control Panel button - Direct Sound Input Ports - Enable one device (default input will now show the device). Now you will be able to record sound.
Jul 24, 2008 | Adobe Audition 3 for PC (22011292)
Aardvark Direct Pro 24/96 Audio effects problem
Checkout your sound mixer setting in windows control panel (if you have windows) or in "Preference" or "Advance setting" tabe in adobe audition software
Check your connecting cables have appropriate jacks
Mar 19, 2008 | Aardvark Direct Pro 24/96 Sound Card
Playback is faster than recorded
close that windows
now click on it again (left click) and choose mixer
Does your mic show up there ?
Jan 11, 2008 | Creative Labs Sound Blaster Audigy LS...
Computers & Internet Logo
113 people viewed this question
Top M-Audio Computers & Internet Experts
Edward Easley
Edward Easley
Gustavo Ortiz
Gustavo Ortiz
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
