A friend of mine reset my password for me and didnt write it down. He told me what it was but I was extremely busy. And to make matters worse he does not remember what he reset it to. I have tried numerous possible passwords and none of them are correct. Can you please tell me how to reset or even recover my password that is in the computer right now?? Please HELP!!!
SOURCE: BIOS Resetting...
Please open this link this will help you
http://www.thenetworkadministrator.com/biospasswords.htm
And dont forget to rate FIXYA if it didnt help please reply but dont rate any rating
Thanks
Regards
SOURCE: HP Pavilion dv2725en Notebook PC bios password reset
you have to do something called a system recovery this will delete all your memory but you can get help saving the memory from geek squad if you are willing to pay $100 anyway the system recovery requires a disk if you dont have it get it from tech support but who know there could be other options
SOURCE: Satellite A215-S7416 Bios Password
you're out of luck, unless you're familiar with "shorting" the bios chip.
Of course, you can contact Toshiba for a workaround. Proof of ownership is necessary.
good luck
SOURCE: FORGOT HDD SYSTEM PASSWORD CANT OPEN TOSHIBA SATELLITE A105?
Long time ago , I was confronted with the password problem. Finally , my friend Jane introduce the Windows password Reset.It help me access windows. It's great!
http://www.resetwindowspassword.com
SOURCE: Can't remember BIOS passoword on Toshiba Satellite L355D
You will have to contact Toshiba Support directly. The CMOS battery is soldered to the board, so you cannot remove it, and there are no jumpers to switch/short. Good luck.
Test your PSU or replace it if your power supply units fan
is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or
to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including
electrical extensions,IDE,SATA
the leads from your
"((motherboard to your hard drive))" make sure they have a secure connection and
are not faulty or just replace them they could be faulty
make sure all leads that
are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections
and are not faulty even the electrical extensions or just replace them they could
be faulty a computer
needs its connections to continue its cycle and have an end so any faulty leads
will end up with a computer error hope this helps
