Hi, I am thinking of buying a new TV, probably either a 42"/46"/50" Panosonic with Freesat. I have a Panosonic DMR-EH50 DVD Recorder which I hope to connect to this new TV. Will I be able to record all the Digital and freesat programs or do I need to get a new digital DVD recorder with/without Freesat/view? Similar question relating to a Panosonic NV-HD636 VCR which I also have. Finally I also have a Panosonic DVD Home Theatre Sound System SA-HT75, could I set this up alongside either the DMR-EH50( or a new digital DVD recorder should I not be able to use th DMR-EH50). Sorry if this seems a silly or long question but all of these appliances are not that old and it seems a waste with the enforced changeover coming to this area in April 2009. Many thanks.
SOURCE: SETTING UP TJE PANASONIC DMR TO OTHER COMPONENTS
http://www.altex.com/product_info.php?products_id=9207 here is a link to a audio / video switch box you need one of these make sure it has several audio video in and at least one audio/video out
hook all you rca cables up to the audio/video in from the cable box, tv, and dvd/vcr combo then out to the surround sound youll also need to get some rca cable splitters for the out so you can run it back to the audio/video in to the tv as well as the surround sound here is alink to what they look like
http://www.altex.com/product_info.php?cPath=344&products_id=6201
youll need thre of these of course when hooking it up dont pay attention to the color on these just the ones from the tv and surround sound and thats it your done it will all work if you want it to were you dont have to get up and push a button everytime most of them if you push all the buttons in at one time theyll stay like that
SOURCE: CONNNECTING THE DMR-EZ475V TO A TV, THEATRE SYSTEM AND CABLE BOX
Solution #2
posted on Feb 09, 2008
jdrrwoods
Rank: Wiz
Rating: 84%, 12 votes
SOURCE: Reception upgrade or what ?
Older sets are fitted with analogue tuners which can't handle digital signals. The only way round the problem is if the TV can be used as a monitor via a scart input. The external freesat or digital set top box contain digital tuners which can then display the required digital information on the TV. These external units have scart output sockets at the back, specifically for this purpose. So it's a scart lead from your external digital device to the scart input socket at the back of the TV. The remote control for your external box is then used to select the required programmes
