I was driving to the shops when it started raining. When i was done shopping the car wouldn't start.
When it's cold my 2003 Mercedes Benz s500 w/not start why..please
Possibley try spraying the ignition leeds with some wd40 or equivelent or it could be the imobilezer which is worked from the drivers side door if none of these can you here it prime befor the engine starts can you here the fuel pump there is a relay thats in the boot for the pump check this not normally bad starters prety bomb proof i have a 1994 c180 18 years not had a bit problem with it i would check the few points i have listed above before spending any money hope this helps ivan
SOURCE: Engine cant start whenever it is raining
check on the passanger side of the car to see if the floor is getting wet as well because it sounds as if your computer is getting wet behind the glove box while at home on a nice day wash the car and check it all over for leaks because the computer or something is getting wet in the car it may be a bad seal around the windshield
SOURCE: STALLING PROBLEM TURNED INTO NO START 1990 MB 300 SL
hello,good day,first we are in fuel side,better to install a fuel gauge,to determine the right pressure, is not mention your fuel pump relay,this should also check,some occasion the power supply is missing,now if all is in order (fuel side) then your switching unit(transistor box) need tobe check,assuming your engine is 103 engine,ty
SOURCE: when car is locked the alarm sounds without car
re-adjust your vibration sensor! of your alarm!
SOURCE: Cruise control quit working a couple of weeks ago.
You can try to reset the cruise control system by disconnecting the battery from car terminals, wait for 5 minutes, and reconnect back the battery. But be sure to have the original radio code if necessary, before battery disconnection.
SOURCE: I've had my 320 CLK
ignition switch contact or starter motor given up the ghost ,try a jump start and see if that works ,do the lights go dim when you try to start it??if so then its a flat battery or a old battery thats just died on you.These vehicles do have a big ignition lock in the dash and these just dont go wrong like a VW but its possible?
