Sylvania DV220SL8 DVD Player/VCR Logo
Posted on Oct 24, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The DVD stopped loading
I was watching a movie, the DVD froze as they do at times, I took out the DVD and put it back in the player and now it will not load the DVD, the VHS part still works.
Anonymous
Level 3:
Top Expert:
  • Sylvania Master 14,553 Answers
  • Posted on Oct 24, 2012
Anonymous
Sylvania Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2718525
Points
48227
Someone first will have to open the player to see if mechanism jammed or something out of position and to see what is actually happening--this is the flaw with combo units--one part fails to work and that can be the end of the unit.
2 Related Answers
Anonymous
  • 10 Answers
  • Posted on Aug 12, 2012
SOURCE: the dvd in my sylvania dvd player keeps getting stuck, can I fix it?
dvd players are a touchy thing and when they start doing this its time to get a new one or have it repaired.
A
Anonymous
  • Posted on Apr 21, 2008
SOURCE: Sylvania SRD3900 will play DVD+r
Sylvania SRD3900 remote codes
My DVD Player will not play my movies
Try cleaning the lens with a DVD cleaning kit.
1helpful
TruTech tv with built in DVD player not playing DVD's
the possible of dvd, its lince, its possible damage, specialy when use dvd has scrahts. try to clean useing cotton bads only, clean smothly, then try to use,
DVD side won't load to play
yea, your going to haft to reuturn the unit and get a new one. some times the lens messes up like that, sorry
I was watching a dvd when the screen suddenly froze. I thought it was just the disk so I took it out to clean it but when I put it back in, it still wouldn't play. It keeps saying loading when I put the...
I'd say put an audio cd in an see if it reads it if not you may be able to get a dvd cleaner which is a disc that will clean your player internally. Hope this helps
Trouble Loading & Not Registering To TV
I can't say 100% but it sounds similar to the problem I had with the same model . The sleep mode in the on/off switch had gone bad and a new switch fixed the problem. It was about $42 to rtepair at my local electronics repair shop. Hope this helps.
Parental Controls feature
Hey Aurora, After you put your password in, go back and change the password using blanks spaces. Then it should reset to 'parental control off'. Let me know if this works. Some Sanyo models are different to reset.
Movies on my recorded discs freeze after a few minutes of play
Sometimes this unit gets "confused" - not sure why -- but try first using a CD cleaning disk and let it start and stop a couple times (sometimes lens gets dirty and does this) - if that doesn't help then try unplugging unit and leave unplugged (from wall socket) for about 30min then plug in, set local time and then see if the disks play okay - sometimes this "resets system"
DVD player froze, now only turns off
Sounds like the power supply in the dvd player has failed. It works just well enough to turn on the led infront but as soon as you go to do anything it shuts off. This is common in cheaper dvd players. Unless you can troubleshoot electronics. Or know someone that can. Your best bet is to unplug the unit and disassemly and retrieve your dvd.
Top Sylvania Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
