I am haveing trouble getting furnace blower out.
The entire blower and housing slides out you should find the mounting screws on each side of the blower housing they may be sheet metal screws either on the top or on the bottom. After you remove the two screws the blower should slide out. If you remove the blower wheel from the shaft make sure to tighten the lock screw on the flat side of the shaft. Another trick to pull the blower wheel from the shaft is loosen the lock screw and push the wheel in then clean the shaft wit fine sandpaper otherwise you can cause the wheel to jam up because dirt gets stuck between the wheel and the shaft
SOURCE: I removed the blower from
You don't have the t'sat wires to the outdoor unit hooked up. They should be on the y & c terminals. If they are you may have a burnt out contactor coil. It should read 24volts at the contactor coil when you are calling for cooling
Dirt is the biggest enemy of your furnace. It can waste fuel and drastically lower efficiency. Dirt affects all three basic components of your furnace, so cleaning is the most important part of regular maintenance. The three parts of the furnace should be cleaned: the filter system, the blower, and the motor.
The furnace filter should be replaced or cleaned at the beginning of the heating season and about once a month during periods of continuous use. To check the filter, take it out and hold it up to the light. If it looks clogged, replace it with a new filter of the same type and size regardless of the length of time it has been used.
Step 4: Clean blower assembly, belts and pulleys to blower, and motor housing. Cleaning blower is critical if furnace has a squirrel-cage fan, because openings in this type of blower often become clogged with dirt. To clean blower, remove panel that covers filter to gain access to blower or panel on front of furnace. This panel may be slip-fit on hooks or held by series of retaining screws. Access to inside of blower is usually gained by sliding out fan unit, which is held on track by screws.
If power cord to fan assembly is not long enough to permit fan unit to slide all the way out, disconnect cord. Mark wire connections first so you'll be able to reassemble unit correctly. With toothbrush, clean each fan blade and spaces between blades. Then, with vacuum cleaner hose, remove all dirt and debris loosened by brushing. Vacuum belts and pulleys. Wipe motor housing clean to prevent heat buildup in motor.
