Your question is a little confusing, but the only way you can use a already loaded hard drive in another computer is if you put it in the exact same model computer. Windows will crash before it even starts since all the drivers are wrong. If your just trying to install a new blank hard drive then yes you will have no bios problems. Just make sure you buy the correct hard drive. There are different connectors, IDE and SATA.
Testimonial: "If there is any other way I can get the data from my dead laptop(needs reflowing), any other way I can connect the drive to another computer ? Dead laptop model: Compaq presario CQ5 106AU "
Yes you can put the hard drive in an external usb enclosure and and pull the files off that way. But make sure you get one for your connector. IDE has pins all the way across the drive sata has a few pins and 2 flat plastic connectors. Also make sure it is for a 2.5" hard drive. They are like 5-10 bucks on ebay.
I want to backup data from another hardisk in a dead laptop. Can i remove my HD in my inpiron and just put the other one and my laptop will pickup the HD without any BIOS problems. Simply put, can I change my hd in my laptop to any other compatible hd ?
