SOURCE: to set the clock on a jensen cd 2010x cd in car player
1. Press DISP for approx. 3 seconds until you see the clock flashing. 2. Use the up and down to change the values and the right and left (<< >>) to change from hours to minutes. Then hit the Disp to exit.
SOURCE: Jenson CD330X CD Player
The problem is that the bat handle is broken. you need to dissassemble, and repair the blue plastic piece. Use epoxy, that's what I did. It worked.
I can't set my clock either.
SOURCE: I'm looking to find a faceplate
there is one there now for $35 12/17/2008 and it's buy it now and $10 shipping in the usa
SOURCE: cant program car radio
Sorry to say, but you will have to pull the unit and locate the wiring to it. Have a tester for dc voltage and find the power wire that goes on and off with your key. Once that wire has been identified, Find a wire that has 12vdc all the time even with the key off and go to the one that went off and on and cut it. The wire going to the unit strip and splice to 12vdc that is on all the time. Cap and tape the wire you cut that leads away from the unit.
If you need more help feel free to contact me.
Mike
SOURCE: Jensen XCD9120 - Clock Setting or Manual
Press DISP button. Within 3 seconds press and hold BAND button and press TUNE+ (plus) to change minutes, TUNE- (minus) to change hours
