Question about Cooper Wiring Devices 6009W-K ROTARY DIMMER REPLACEMENT KNOB WHITE
I want to replace a dimmer knob with a normal on/off switch but the dimmer has two black wires that are spliced together on each side so a total of 4 wires. Which two would be the live and why are there four wires spliced into two?
Posted by HWoiwode on
Al Kupchella
  • 843 Answers
Could be several reasons, but here's what i think is most likely. First, there are other wires in the box that are not connected to the switch - 4 ground wires all connected together, and 4 white wires all connected together. You only 1 hot black wire coming into the box. This wire goes to one side of the switch, but it is tied to a 2nd black wire that is going on to something else (like another switch or an outlet). That counts for two of the black wires. The other two black wires are on the output side of the switch and are going to two places - pehaps the switch is used to control two ceiling light fixtures. The good news is that unless you have a lighted switch there is no difference between the IN side and OUT side of the switch - it works the same either way, and you can connect the switch just like the dimmer was hooked up - even if my explanation of why is not exactly your situation. Good luck!
Posted on Oct 24, 2012
3 Related Answers
Anonymous
  • 22 Answers
SOURCE: replace dimmer switch with toggle
Both wires should be black because the switch interrupts or breaks the connection to the light. It doesn't matter which black wire goes where. Just be sure the power is OFF and then undo the dimmer switch (usually has wire nuts connecting the black leads) and then connect the wires to the new toggle switch.
Turn on the power and feel good about your work!
Posted on Jul 24, 2009
dennis bullard
  • 4090 Answers
SOURCE: I want to replace dimmer switch with standard switch
the two black wires spliced are Live wires ( same value as RED) the other single black is the return. The two twisted blacks from the wall go into ther active hole of the new switch and the single into the return. No third wire for earth is needed
Posted on Jul 27, 2009
VtToolMan
Mark
  • 704 Answers
SOURCE: wiring dimmer to knob and tube
You should attach the green grounding wire to the metal box using a green grounding screw. You don't want to leave the wire loose, as any contact with the switch screws could cause a short.
Also, you should wrap the switch with at least 2-3 complete wraps of electrical tape to prevent the screws from contacting the sides of the wall box.
As a side note, you should likely have a complete check done on your house if you still have knob and tube wiring installed, as the dangers associated with this very old wiring are many. Typically, older K&T wiring was used in homes well over 60 years ago and houses then only had minimal electric current drawing devices, such as lights and a couple of other small appliance devices (toasters, coffee pot, TV and radio, etc.)
The problem with older homes with K&T wiring still in use, is that the circuits can be easily overloaded with modern electric convinences and lead to a possible fire situation, especially since there is no dedicated ground to help mitigate short circuits, etc. Also, the rubber based insulation used on this type of wiring deteriorates after 40 years (+/-) and rodents tend to chew on exposed wires in attics and crawl spaces.
I don't wish to alarm anyone, but as a Licensed Master Electrician, I've seen and done my share of repair work involving Knob & Tube wiring and even had a couple of homes that had a mix of it and other, newer wiring, that I've completely rewired. Many states require K&N wiring be replaced before a home can be sold, so getting a jump on it will make your home safer and better suited to operate all the devices that people tend to have, in today's society.
Hope you find this Very Helpful and best regards!
Posted on Sep 10, 2009
How can I wire 3 Lutron Dimmer switches in a series? Each switch will control a different set of lights. I pig tailed the black power source to each of the dimmers. I ran the black wire from the light...
yes, take the white wires off the switches and splice them all together with a wire nut. Run a hot wire to each of the switches and then run the switch leg (black) from each of the fixtures to be controlled to each of the dimmers.
Jul 09, 2014 | Leviton Electrical Supplies
How to wire tree seperate lights
Not sure from your description.
Copy following link:
http://waterheatertimer.org/How-to-wire-switches.html#triple
Add a comment for follow-up
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 24, 2013 | Leviton 1755 Triple Rocker Switch Decora
How to wire up the dimmer which wires to what....... active - remote - load ...??? red & black wires to which...?? thanks
first of all, a 3way dimmer uses 3 wires, the wire you take off the discolored or black screw is your pivot or feed goes to the black of the dimmer,the other two wires splice usually two reds splice one to each.will need more info if you are using a remote switching system
May 23, 2011 | Electrical Supplies
I'm wanting to install a combination outlet/switch device. Both will work off the same circuit but be independent of each other. I want the light to work from the switch, with the outlet constantly hot. ...
How many sets of wires are coming into the box?
If the box is in the middle of the circuit you will have a power-source black & white wire coming in and a power-source black & white wire going out. And in this case for the switch - there must be a black and a white wire going to a light.
Typically with a switch/outlet combination all the white wires will splice together with a white pig-tail wire to feed the neutral side of the device. The two black wires from the power-source will splice together with a black pig-tail and feed the hot-side of the device. The black wire going to the light will go on one side of the switch.
Looking at outlet/switch device from the front the large slot side of the outlet will be the neutral side and the smaller outlet slot will be the hot side. The neutral side screws will be steel colored and the hot side screws will be brass colored. The white wires will go to the neutral side steel colored screws, and the black wires will go on the hot side brass colored screws on the outlet.
The black wire comig into the box from the light is called a switchleg and goes to a brass screw on one side of the switch. The brass screw on the otherside of the switch will be for the black wire coming from the power-source.
Hope this helps - and please:
TURN THE BREAKER OFF BEFORE YOU START WORKING WITH THE WIRES!
Mar 16, 2011 | Cooper Wiring Devices Combination Switch &...
My T101 timer switch is installed allready, but I dont know how to hook up the pool filter to it, it has three wires on it, black,white and green
If the timer is already installed, then the incoming (from the breaker or source) black wire should be connected to the #1 terminal. The incoming white wire should be connected to the "A" terminal and the bare (or green) wire should be connected to the "GR" screw on the (lower) case.
To connect the pool filter (load) to the timer, connect the black wire to terminal #2, the white wire to terminal "A" (along with the incoming white wire) and the green wire to the "GR" screw (along with the incoming bare or green wire). Usually one twists the two green or bare wires together with a short pigtail using a yellow or red wire nut and then connects the pigtail to the "GR" screw.
The two white wires don't need to be pigtailed, as the "A" terminal is designed for two wires.
Apr 25, 2010 | Intermatic T101 - 24 Hr. Dial Time Switch...
The task was to replace a bathroom vanity light. Before removal of the old light, the dimmer switch worked correctly. I didn't touch the dimmer switch. After removal, the wall wires consisted of two...
Alan
Generally, 3 wires indicate a "3way" switch where you have 2 switches at opposite entrances to a room. Both the Red and Black Can be hot, depending on the other switches position. But, a red wire would normally only be found at the switch box not the light.
What I'd suggest, is that you get a multimeter, and use it to determine the hot wire and the ground/neutral. Once you know which wire is hot, connect the hot to the black lead, and ground/neutral to the white lead of the light. That is the only SAFE manner I can see to resolve this.
Mar 02, 2010 | Electrical Supplies
I need a pull chain DIMMER switch for my fan light. Only one set of wires supplies the fan and light. Surely SOMEBODY has a pull chain dimmer ??? Thanks. Bill
Bought three fans for the bedrooms, all hunters with pull chain dimmers. Less than one year and two of the three dimmers are shot. Can't find a replacement so I bypassed it. Remove light assembly and unplug 9pin connector. Remove black vented dimmer assembly by removing wire nuts and disconnecting the 2wire connector(black and white wires). Cut the 2wire connector off and save it in case you find a part someday. Wire nut black to black(hot) and white to white(neutral). You will disable the pull chain by wire nutting those two wires together.
Jul 29, 2009 | Hunter Ceiling Fan Light Switch Control
Jul 27, 2009 | Cooper Wiring Devices 6009W-K ROTARY...
How to wire combo switch
you should have 4 wires total (not including grounds, which get twisted together and connected to green screw) you have to know which is the power lead, and which goes to the light! 2 blacks, and 2 whites ...the 2 whites go together and connects to the silver screw, and the 1 black power lead goes to the gold screw, the other black wire(to the light) goes on the opposite side of switch above the silver screws on another gold screw
Apr 06, 2009 | Leviton Combo Switch Receptacle - 5225-T -...
Trying to hook up a dimmer switch it has a red black yellow and green wire the box has a black white and ground which wires get connected together?
For a single-pole installation:
1. Connect the 2 white wires together (one from the source and the other to/from the light fixture) - 2 wires
2. Connect the black wire from the source to the black wire on the dimmer switch - 2 wires
3. Connect the black wire to/from the light fixture to the red wire on the dimmer switch - 2 wires
4. Connect the ground wires - 3 wires
Mar 23, 2009 | Electrical Supplies
Cooper Wiring Devices  6009W-K ROTARY DIMMER REPLACEMENT KNOB WHITE Logo
272 people viewed this question
Top Cooper Wiring Devices Electrical Supplies Experts
Dennis Boxerman
Van Allen
Van Allen
Are you a Cooper Wiring Devices Electrical Supply Expert? Answer questions, earn points and help others
