Question about Samsung Dvd-vr320 Dvd Recorder
Setting up with a bog standard, cheap and nasty dvd player, its plugged in and it tells the tv what 'mode' to use to play, and straight away, as soon as the power goes on, the dvd screen displays on the tv ... but ive connected it up as best i can (we have sky, so theres no actual aerial to speal of) but the tv just displays 'no signal' and never shows the dvd screen, on lucky occasions it TRIES to show it (possibly switching to 'AV MODE' on the tv ?) but after 3 seconds it will revert back to HDMI mode (sky tv mode) - do i just need some more wires -possibly 'colour to colour' leads ?
Posted by jenny robinson on
5 Related Answers
ginko
Ginko
  • 19396 Answers
SOURCE: Samsung 40" lcd - Connecting to PC saying 'MODE NOT SUPPORTED'
First of all, check that the TV is set on PC input when you use PC video input at the back.
Then you may also need to go to video and display properties>>settings, from control panel (personalize on Vista).
There lower down resolution and ensure that frequency is set the same as tv.
Posted on Jan 02, 2009
Anonymous
SOURCE: Picture Mode reverts always to Dynamic after several minutes
The set was a store demo, and the options were set so they could not be adjusted. On instruction from Samsung I pressed MENU and VOLUME buttons on the side of the set and hold for 7 seconds The display reverts to Standard from Dynamic. The Remote Options button showed Store Demo, but now shows Standard. All memory functions seem to function now. Thanks for your help.
Watty2c
Posted on Jan 17, 2009
Anonymous
SOURCE: Problems with the picture mode on my samsung 46''
Your TV is in DEMO-STORE MODE.
Go to menu, find Plug & Play option, start it, and when asked, select Home Mode, than Enter and than just Exit.
Enjoy Your TV!
Posted on Jan 22, 2009
Anonymous
SOURCE: digital - Weak or no signal digital coax when hdmi dvd player on
if u have placed your DVD next to your tv ... just maintain distance between then and check out
Posted on Apr 01, 2009
Anonymous
SOURCE: 931B tries to come on but shuts back off
Problem solved by changing 3 capacitors (C112, C113, C316).
Replace the 470uF 25V with a good quality low ESR type and the two 820uF 25V with 1000uF 25V low ESR types.
The 1000uF caps should be 10x20 in size, however I managed to get 13x20 caps in, but it was a bit tight.
Posted on Apr 22, 2009
How to hook up DVD player to 19' led HDTV
The modern way is to buy a HDMI Cable
Plug it in to the HDMI Port on back of DVD Player
Plug the other end into spare HDMI Port on LED TV.
Put in a DVD & hit Play
Use remote control to select HDMI port on LED TV
If it does not have a HDMI port then you need a converter box which picks up the Red & White (sound) & Yellow (viideo) and converts to HDMI standard.
Aug 13, 2014 | Televison & Video
The video portion won't play but audio does
It looks like you've got a plain, old "480i standard definition" TV. The inputs on it will likely be limited to S-Video, RF Coaxial (cable) and one or more sets of "A/V" inputs that consist of 3 jacks - 1 each yellow, red, and white. Without knowing the make & model of the TV I can't be sure which / how many inputs it has. It looks like you're trying to play a DVD. Most DVD players only offer A/V type connections - again - you didn't provide this info so I'm forced to guess. The Yellow jack (on TVs and disc and tape player / recorders almost always provide the higher quality A/V jacks) is for the video signal and the Red & White are always the left and right stereo audio jacks. The cables used to connect devices to the TV have the same colored plugs to make matching them up easier than if they were all the same color. If you accidentally connected one of the red or white audio plugs into the yellow video jack, you will not have a picture. Check BOTH ends of the cable - at the TV and at the DVD player. All three plugs must be connected to the corresponding colored jack.
If it is connected properly, your DVD player might be one that was a more expensive type that offers "480P Progressive Scan" output along with the standard "480i interlaced scan" output. The 480i output was called "standard definition" and 480P was called "enhanced definition" and provided a better picture. If your TV only supports 480i, it will not be able to display a 480P signal. You will need to check the DVD Player manual to find out how to return the output to 480i again. If you no longer possess the manual, you may either Google it or provide the brand and model here so that we might take a look for it for you.
In the event that you are using RF coax (cable) to get the signal from the source into the TV, you may just be trying to watch it on CH4 instead of CH3 (or vice-versa). Try changing the channel up or down one from where it is to see if the picture comes in.
I hope this helps & good luck!
Feb 08, 2013 | Televison & Video
My DVD is playing my videos in black and white .. It's a Panasonic tv model is tc-L32c5
follow the steps. God bless you
Insert a DVD lens-cleaning disc into your player and press "Play" to clean the DVD laser, eliminating picture problems due to read errors. Do not use a CD cleaning disc as the brushes on these discs can damage your laser.
  • 2 Wipe your DVDs clean of all visible marks and dirt using a lint-free cleaning cloth moistened with rubbing alcohol or glass cleaner. This further fixes read errors which can damage the quality of picture and sound.
  • 3 Disconnect your DVD player from the TV or receiver you have it connected to. Reconnect the DVD player directly to the "AV" or "Video In" port of your television, firmly pushing the plug into place, to eliminate possible noise from the receiver and ensure a clean connection.
  • 4 Connect your DVD player using an S-Video, component video or HDMI cable. Standard yellow/red/white RCA connectors cannot carry the high-quality signal that DVD discs are capable of transmitting, and will display a particularly poor picture on flat-screen high definition televisions. Use an HDMI cable, if your television and player support it, or a red/blue/green component video cable.
  • 5 Press "Setup" on your DVD remote and enter "Picture Settings." Make sure your DVD player is set to display images in the correct screen format ("Widescreen" or "16 x 9" for HDTV sets, "Standard" or "4 x 3" for older square sets) and scan mode. If you are using a DVD player that supports "Progressive Scan" on an HDTV or flat-screen set, activate this setting; for older sets, choose "Interlace" if given a choice.
  • Nov 14, 2012 | Televison & Video
    I put in a dvd, it starts to read it, and in a couple of seconds it ejects
    Hello; There are many laws and rules controlling what you can watch on all DVD players, built into a TV or separate player. If you go buy an MGM or other dvd of some movie at Walmart , Best Buy ETC it should play in your DVD player, But if You or somebody " Burned a DVD" , It Likely won't play. If The DVD is an original store copy and still won't play, the DVD chassis must be replaced. BIG BUCKS. Just buy a Cheap DVD player and plug into the jacks on the back of the TV and save a TON of money. John
    Jun 27, 2011 | Emerson LD195EM8 19 in. LCD TV
    We have a 23" Toshiba with a internal DVD player.
    No,tv internal DVD player are not on sale by itself as a seperate unit,only can buy it from the tv corporations themselves and it not cheap and have to have experience to putting it in into the tv internal tv itself.The tv internal DVD player now,could be the laser eye data reader have problems reading mp3 and mp4 files on the DVD disc,which are video files.Now tries to play more than one DVD movies dic,tries like to play like 5 to 6 original DVD movies.One disc don't play tries another DVD disc.Tries this might forcing the laser eye reader to read DVD dics again and than might fix it to read video files again.Or just buy an external DVD player hook it up to the tv and play DVD disc on to the tv video modes.DVD players external devices are really cheap these day,like can buy new one for $40.
    Mar 25, 2011 | Toshiba 23HLV84 23 in. TV/DVD Combo
    We have a Philips Magnavox Model #TP3284C101 TV and plugged in a Durabrand DVD Model #DVD1002 player to it. It will only play in black and white on this TV. But when we plug the DVD player into another TV...
    It sounds like you have a standard problem.
    Is the TV you are using, that gives the black and white picture, the same as the other ie, both NTSC or PAL and both on RGB or Y-C or S-Video?
    Check to see what is required and set the DVD player accordingly.
    Hope that helps.
    Dec 10, 2010 | Philips Magnavox 27MS343S 27" TV
    I have a Phillips dvd player DVP3110K/75 that will only play region 4 and i have dvd's from overseas, can you help with changing the region to REGION FREE SO I CAN PLAY THESE OTHER DVD'S. Thanks Elaine.
    buy a cheap and nasty machine and you will be surprised at how universal they are. lol. When my samsung gets fussy, i use the cheap and nasty and presto, "movie time"
    Sep 16, 2010 | Kitchen Ranges
    Switching my tv from tv setting to video setting to play vcr
    Should be a button on the TV or remote that says Video or Mode. Make sure player is on before hitting the button and wait a few seconds.
    Mar 21, 2008 | Televison & Video
    Samsung dvd recorder model vr-325
    Ok I have been here before. The problem is your DVD burner in your DVD player unit may not be burning the disk in a format recognized by the Computer, or the laser may not have burned the disk to the set standard, and while it can play on that DVD player when you move it to a nother player it will not play. Well what we can do is Test the reverse first. Burn a DVD on your computer and try to play it on your DVD player and on the other TV. Then what I want you to do is to clean the lens of the player and try to burn a disk and play it on your computer. Let me know how this truns out.
    Sep 10, 2007 | Samsung VR-325 DVD Recorder / VCR Combo
    Samsung Dvd-vr320 Dvd Recorder Logo
    37 people viewed this question
    Top Samsung Car Audio & Video Experts
    Marvin
    Marvin
    Vernon Taylor
    Are you a Samsung Car Audio and Video Expert? Answer questions, earn points and help others
