How can i format my phone tw1 duo after its drain it cannot open even though i charge it
SOURCE: i forgot my input phone
you can try resetting your phone through codes. its the safe way to reset your phone. because when you reset your phone through software or hardware there are possibilities for data getting corrupted or lost. but there is no such possibilities when you reset through codes. thats y i prefer this method to reset my phone. i got the codes from this site Classicunlocking.com to reset my phone. try it
SOURCE: My myphone is on headphone mode and it can't go back again even if i remove the earphone
u have 2 flash the mobile
SOURCE: can opera mini be used in tw1 duo myphone and get
Thanks for visiting FixYa!
I've heard through the grapevine that it may be possible once or twice but you'll be cut off very quickly. Also, it's a crime to access the Internet in such a way. I'm going to caution you not to try it. It's good advice. I hope you take it.
Testimonial: "thanks for the advice,,you've been very helpful..."
SOURCE: my phone tw1 duo problem restart when trying to connect to the internet
mY Dear:
First:
restore your Phone Settings
IF Restart problem not Solved So
Secend Option:
Please Format Your Phone
we can solve this problem but i need you to backup the whole DATA that you have in the phone and perform this reset procedure.
*#7370# or *#7780#
Default security code is 12345
release some memory then it will b opened
your phone or memory card get attack by virus. pls do a format phone and memory card.
If Problem Not Solved So
Very Best Solution:
flash new software install in the phone problem will solved quickly
