Forgot my phone lock code
SOURCE: how do i unlock the phone lock on samsung gt-b3310
If you want to unlock your phone put a sim from another company then
type *#9998*3323# it will reset your phone. Push exit and then push 7,
it will reset again. Put your other sim in and it will say sim lock,
type in 00000000 then it should be unlocked. Type in *0141# then the
green call batton and it's unlocked to all networks. This code may not
work on the older phones and some of
the newer phones. If it doesn't
work you will have to reset your phone without a sim in it by typing
*#2767*2878# or *#9998*3855# (not tested)
Please let me know if you have any further questions or concerns.
Thanks.
SOURCE: i forgot the phone lock
You can try formatting the phone, formatting will help you set a new lock code. To format the phone, type this on the Dial-screen.
*2767*3855#
Note: Don't forget to remove your sim and memory card before dialing this number. It'll reset all your factory settings.
SOURCE: samsung gt s5233a unlock code
here are actually two codes that you can actually use to reset the password. Below are these codes. Please dial them up and have the problem solved.
This mean the security code will be reset to 0000. This will allow you to format the phone easily.
All versions of Samsung GT-C3222 are supported but your GT-C3222 must be locked to Europe network. Please use USB unlocking for non-Europe models (if available).
Getting the unlock codes is very simple process. You just need to read you IMEI number (type *#06# on your phone keypad) and submit it to Unlock
