Samsung SyncMaster 740N 17" LCD Monitor Logo
Question about Samsung SyncMaster 740N 17" LCD Monitor
My Samsung Syncmaster 740n monitor blackout. the power led blinks. some times it regain display. what may be the possible causes.?
Posted by Rabeesh... on
francoise cleofas
    Genius:
  • Samsung Master
  • 2,432 Answers
Have you been check for a bulging capacitors at the power supply board.
Posted on Oct 24, 2012
5 Related Answers
Anonymous
  • 406 Answers
SOURCE: How do you open up Samsung LCD 740N monitor?
This monitor contains a latches to open. Its recommended that you use suitable tools and service manual.
If the unit is in warranty its recommended that unit to be serviced by service Engineer.
Posted on Dec 30, 2009
Anonymous
  • 36 Answers
SOURCE: samsung syncmaster 740N 17 inch no display
manual and drivers
http://www.samsung.com/it/function/search/resultList.do?searchWord=913v&ct=0&sort=0
Posted on Apr 14, 2009
Anonymous
  • 5 Answers
SOURCE: samsung syncmaster 740n monitor problem
Add a 50 ohm between pin 5 and 6 of the NT68F63LG IC.
Go to this link to learn the details. http://translate.google.com/translate?hl=en&sl=es&u=http://www.dtforum.net/index.php%3Ftopic%3D55304.msg1010695085%3Btopicseen&sa=X&oi=translate&resnum=3&ct=result&prev=/search%3Fq%3DNT68F63LG%2B50%2Bohm%26hl%3Den%26rlz%3D1T4SUNA_enUS219US220
I tried this fix on my monitor and it works now.
Posted on Aug 28, 2008
Anonymous
SOURCE: samsung monitor problem
update the driver of your video card or download the Everest Ultimate Edition
Posted on Aug 07, 2008
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: After changing old model monitor for Samsung
First, try it on another PC first.
Second, the video resolution of your PC should be set to 1280 x 1024 @60Hertz.
Unless it has problem inside, then you will need to open it up.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Aug 23, 2010
Samsung LCD monitor Model 740N no display.
pls chek 1000/25cap ,and inverter fuse, and 5402 ics
1helpful
I want power supply circuit diagram for samsung 740n lcd monitor
Samsung SyncMaster 740N LCD Monitor
Click the link below to download the Schematic diagrams:
http://manuals.xtreemhost.com/dw/samsung_740n_SCH.pdf
Note: PDF manuals require the Adobe Acrobat Reader for viewing and printing.http://get.adobe.com/reader/
My Samsung SyncMaster 740N occasionally turns itself off. Timing varies and the condition varies. Usually the screen just goes black - from seconds to hours after it is turned on - the blue LED remains...
This could be because of the 'eco' friendliness of the monitor. Basically a lot of monitors are designed to turn off into a low power state when not in use so to preserve power and life of the monitor. I would return the monitor as the sensors that control this seem to be broken in your monitor.
SyncMaster 740N 17" LCD Monitor: I have two of the SyncMaster 740N's as security mo...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
740N blank screen
I would inspect all the caps, if you find even one bulging top/leak you should replace them as a set.
See failed SAMSUNG here, use good caps, such as PANASONIC FM or FC series from DIGIKEY.
Service manuals:
http://elektrotanya.com/?q=showresult&megnev=SAMSUNG megnev2 =% 20 & 740N = & Category = & kat2 schematics
No display blinking power led on cold boot
I think a capacitor on PSU board has popped.. Check it. replace it for a $1.00 part
Samsung monitor problem
15helpful
3answers
Samsung SyncMaster 740N 17" auto adjustment locked
I just had my Samsung 740N LCD monitor auto adjustment lock 2hours ago.
But i found this cool solution at
www.fixya.com
"Press down
the menu button(1st button on the left) for 5sec or until the menu display gone?"
and it works for me. Hope it will work on you
Thanks
http://www.fixya.com/
Top Samsung Computers & Internet Experts
Marvin
Marvin
Fix It Fast...
Fix It Fast...
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
