Keyboard is not working at all. Does the Asus Eee PC 900 has an on-screen keyboard?
SOURCE: keyboard for my ASUS Eee PC 1000H is not working
Hello, I'm not actually sure if you can do this by yourself, or you might just have to get a technician to fix it for you.
What I would suggest that you should do is to get a replacement keyboard for the laptop, you can even buy it from an electronics store by yourself and get a technician to fix it for you (If you cant do it by yourself), this way it would be cheaper.
This is because it is not always advisable to try and repair a laptop keyboard, because one way or the other, it would still develpo problem again. So its better you change it outright and put the inconvenience behind you.
Hope this helps.
SOURCE: Asus Eee PC keyboard won't re-attach to the motherboard. Help!
On the backside of the connector where the ribbon goes there is a small strip of plastic there.LIFT IT UP ON BOTH ENDS,SLIDE THE RIBBON DOWN INTO IT.WHILE THE RIBBON IS IN IT,PUSH THE STRIP OF PLASTIC BACK DOWN MAKING SURE THE RIBBON STAYS IN PLACE (ALL THE WAY DOWN) WHILE PUSHING IT DOWN.You may have to try it a few times to get it snug in the motherboard connection.Good luck!
