SOURCE: sony model kp-51ws500
You have all three projection tubes that are failing. This was a common issue for this year. Depending on serial number 2 of the 3 CRT's (green and blue) are no longer available. They will have to be pulled and rebuilt.
SOURCE: sony tv red flashes
LED flashes of 8 times are indicative of a "High Voltage Error" which means something along the lines of "T8005 is faulty. (D board)" according to the service manual. Most likely it will need a professional to look at it. A link to the service manual is here: http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
SOURCE: Sony KP-43HT20 convergence problem
Replace STK-392-110s or 150s upgrade with 180s replace both ics.
SOURCE: Sony KP-57WS520 57 in. Rear Projection TV standby light blinks
Please mention how many times standby light blinks on your KP-57WS520
There would be bit long pause between blinks so count the blinks and let me know to help you.
The usual problem is to accidentally hit the "source" button switching the TV to antenna when the signal comes for HDMI or any other source other than the one you were using. So first what was your source ?
