Question about Fisher and Paykel DE09 Dryer
My dryer runs then shuts off after a minutethen wont start again for a little while
Posted by mdroy777 on
Whirlpool dryer LER8648PWO wont start.
make sure door is closed and then if that doesnt do it, open door and look for where the door contacts at closing you will see a little metal table that is like a ground sometimes when a dryer door is closed or slammed the tab might get pulled backwards with the opening of the door again adjust the tab again so contact with door when shut makes contact if that doesnt do it, check your breaker and see if the breaker was tripped too
Jul 02, 2018 | Whirlpool Dryers
My white knight condenser tumble dryer keeps
is it just shutting off or is it tripping ur breaker?
Dryer runs then shuts down wont start up for an hour:
Bad motor windings
Oct 13, 2014 | Dryers
Dryer light stays on when door is shut nd wont run
check the door switch,i don't work on lg but on any other dryer if the wsitch is broke the dryer won't start and if the light is on the switch shuts off the light and dryer will start.if you send the model number i can look up the switch for you.open the door and look around the frame where the door closes into,there should be a push button switch or a little paddle that the door hits,when you push in on the switch it should make a clicking sound or i've seen the paddle broke off.hope this helps or if you removed any wires to the door switch you might of wired it wrong
Mar 30, 2013 | LG Dryers
My computer just went belly up! It is a reconditioned IBM ThinkCenter, a little over 2 years old. It was running normally and then all hell broke lose, cooling fan went berserk sounding like a hair dryer...
Since your PC is two years old its recommended to check your computers hardware check your cooling fan
specially CPU cooling fan if that fan is broken your pc wont work and be careful turning on your PC again and again will burn the processor
Aug 04, 2011 | Computers & Internet
WHEN DRYER STARTS IT WILL RUN FOR A LITTLE WHILE AND SHUT OFF. YOU WON "T BE ABLE TO START IT FOR A LITTLE WHILE. AND WHEN IT STARTS AGAIN IT WILL WORK SOMETIMES.
there is a protection device called a thermal control it could be ovreheating because of an internal clogg or thermal fues located in rear or the heating elements and also check lent trap, check this first
Sep 02, 2010 | Kenmore 62802 Electric Dryer
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Dryr starts to crank up than just stops and wont turn on any more
Hi there, this is motor failure. the actual motor windings are in bad condition at this moment. they are separating and this can ultimately start an electrical fire. the automatic shut off prevents the fire form occurring. you will have to remove the motor and tanke it to an electrialc motor shop for a re thread.
Feb 17, 2009 | Whirlpool GGX9868J Gas Dryer
Dryer won't stop running
the dryer wont stop running only when open door will it start a fire?
Sep 14, 2007 | Kenmore 62802 Electric Dryer
Fisher and Paykel DE09 Dryer Logo
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
Dennis Boxerman
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
