Most times there are a few screws just below the drive. Open the drive, remove the screws, the drive should slide out. It'll be a little stiff at first until it's unplugged.
depending on model it is usual that there is a removal tab one one edge of your drive face. press this in and the removal tab should be visible then pull to remove the drive from the laptop. (do this when power is off) order replacement of drive and insert into slot.
Just to make certain it's not a burnt game on a modded/flashed xbox then more likely your optical dvd drive on the DVD player for the xbox 360 is going out. The lens and laser can be acting up inside and the only way to fix this is to replace the optical dvd drive. You can remove the optical drive and it has 4 screws. You carefully remove the chip inside and transfer to new xbox 360 optical drive which by the way has to be the exact same model to work properly. There are detailed instructions on youtube on how to remove and replace a xbox 360 dvd player.
look directly below the optical drive there will be a sliding switch slide it and remove any near by screws attached to the dvd drive and then slowly pull out the drive. that's it you get your drive out
Yes , You can put Internel Blue ray Drive Into Laptop and the steps are mentioned below for the replacment of Blue ray Drive. Steps 1 - Remove the battery
Slide and hold the battery release latch to the release position.
Lift the front edge of the battery and remove it from the battery bay.
Step 2 - Remove the optical drive
Remove the 7 mm P1 Phillips-head screw that secures the optical drive to the bottom of the notebook.
Use your finger to grasp the edge of the optical drive bezel and slide the optical drive out of the base enclosure.
Step 3 - Replace the optical drive
Insert the optical drive into the base enclosure until the connector is seated.
Replace the 7 mm P1 Phillips-head screw that secures the optical drive to the bottom of the notebook.
Step 4 - Replace the battery
Toe the rear edge of the battery into the base enclosure.
Lower the front edge of the battery and press the battery into the battery bay until the release latch clicks.
thanks that info. realy helped
