HEWLETT-PACKARD EliteBook 8460p Notebook Logo
jonas nilsson Posted on Oct 22, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Turn off bluetooth passkey
I can't turn off the pass key on the bluetooth adapter
Anonymous
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 73 Answers
  • Posted on Oct 22, 2012
Anonymous
Expert
Level 2:
New Friend:
Greenhorn:
Answers
73
Questions
0
Helped
18659
Points
136
You can't turn off the passkey. Usually it's hard coded into the bluetooth device. Look at the documentation of the device you're trying to connect.
2helpful
WHAT IS PAS KEY
Pass Key is a Security of Bluetooth, to avoiding the Mobile Viruses,
most of the time the passkey is set for four zeros (0000) as a default. If that doesn't work, you will need to look in the user manual for your bluetooth device to see what the pass key.
How can I on the bluetooth on my laptop aspire 4743Z?
Connecting your Bluetooth wireless phone with your laptop is called pairing, and I'll use a Blackberry Curve to show you how it works. I'm assuming your laptop comes with a built-in Bluetooth adapter (or you can also get a Bluetooth adapter that plugs into one of your USB ports).
First make sure that Bluetooth is enabled on your phone. For Blackberry phones, that means selecting the "Set Up Bluetooth" application from the main screen, and then selecting "Enable Bluetooth" after clicking the menu button.
Next, set up your computer to allow Bluetooth connections. If your computer comes with Bluetooth, then you'll see a Bluetooth icon in your Control Panel (Start button -> Control Panel from Vista):
control-panel-bluetooth.jpg Double-click the Bluetooth icon and you'll see a Bluetooth Devices dialog. Click the Options tab and make sure the options to "Allow Bluetooth devices to find this computer" and "Allow Bluetooth devices to connect to this computer" are both checked
bluetooth-devices-options.jpg Next, click the Devices tab and then click the "Add" button. This will open the Add Bluetooth Device Wizard, and after verifying that your device is set up and ready to be found (ie. Bluetooth has been enabled on your wireless phone) it will try to find your phone.
add-bluetooth-device.jpg Select the Bluetooth device and click Next to set up a passkey, which is a number that associates your computer with a Bluetooth enabled device. For security reasons, most Bluetooth enabled devices (with some exceptions, such as mice) require you to use a passkey. Using a passkey helps ensure that your computer is connecting to the device that you intended and not someone else's device that is nearby.
You can choose your own passkey or let Windows choose one for you. Click Next and then pick up your phone, which will prompt you to enter in the passkey. After entering the passkey in your phone, Windows will finish the pairing process and your phone will be connected via Bluetooth.
5helpful
Can't find passkey for bluetooth. (0000 won't work)
hey ! you cant give random pass keys..you ll have to provide a pass key to the device to which you are trying to pair with..and that pass key must be entered so that your other device is safe..! so you provide your other device with a pass key ..then try..ok
May 25, 2009 • Cell Phones
17helpful
3answers
Passkey
The passkey is 0000. If you have a problem, reset the headset. Turn the headset off and hold down the call button for 8 seconds until the headset flashes blue and red signaling that it is in pairing mode for the next 120 seconds. While the headset is in pairing mode, use the phone menu to search for Bluetooth devices and select "220Plantronics." (If the headset is already listed in the Bluetooth menu, delete it before searching to pair the device.) When prompted for a passkey, enter 0000. Headset will falsh blue when paired successfully.
1helpful
3answers
Passkey?
the pass key is 0000 but you have to turn the headset back on in order to register. after you hear the second tone "discoverable mode" and the device your registering it to you displays "ns bthdp" turn the headset on and then register
1helpful
3answers
Pass key
All LG Bluetooth Pass-Codes are 000 or 0000.
Vista and bluetooth
Passkeys need to match in both the router/access point and the wireless adapter attempting to communicate with it. Whoever configured the router should be able to supply the WEP/WPA passkey / passphrase / network key If your router does not have a passkey ... you are attempting to attach to the wrong wireless router. (if that is the case you should consider assigning WEP/WPA security to your wireless networl (router/accesspoint and adapters)
87helpful
4answers
Passkey for Motorola H550
Most Bluetooth headsets use 0000 (4 zeros) as the passkey when paring the device to the cellular unit.
Top HEWLETT-PACKARD Computers & Internet Experts
Paul Bade
Grand Canyon Tech
Grand Canyon Tech
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
