Question about Staples SPLP500 Scientific Calculator
Setting date on Staples SPL-P500 calculator
I need to know how to set the time and date on my Staples SPL-P500 calculator. I've tried putting it on "RATE/SET" and pressing "TIME" but nothing is working. Please help! It's been driving me nuts for weeks!
Posted by Katie Grillo on
Julie Corbeil
    New Friend:
  • 5 Answers
You press TIME and then you have a button = (it's also written SET on it) press for few second, it will flash, you can now set the date, DD-MM-YYYY than =/SET than TIME again then, =/SET you can now set the time ( the button X / AM-PM to set am or pm) you press =/SET when you're done, and you're set !
Posted on Jul 02, 2013
1 Related Answer
Anonymous
  • 113 Answers
SOURCE: What do calculator buttons on
Not sure what they all mean but
ON/C turns calculator on or Cancels the current entry % divides by 100 or percent MC - memory clear M+ add to what is stored in memory M- subtract from what is in memory
You can get a manual at http://www.product-support-staples.com/DisplaySKU.aspx?SKU=600516
If this was useful please give me a thumbs up
Posted on Mar 20, 2011
How do I reset to just basic adding
Dont know what you are saying.
Basically turn it off and on if your stuck.
Jan 05, 2016 | Staples SPL-250 10-Digit Display...
How do I load the paper in my SPL-P500 calculator?
Try making a point and feed it in the right place, the feed roller which is only about 1/2 inch wide should pick up the paper.
Feb 13, 2015 | Staples SPL-P500 Printing Calculator
Set up tax rate on staples bd-9512
To set the BD-9512 (Staples Big Digit Tax Calculator)
1. Press ON/AC
2. Press and HOLD the RATE button (for 2 sec)
3. Enter desired Tax amount (i.e.: enter only 13 for 13%)
4. Press TAX + (or TAX - if setting the minus button)
5. Press RATE to save it.
Violia!
Feb 17, 2014 | Casio MS-80TV Scientific Calculator
How to change ink rollers in calculator
How do you change ink in the Staples SPL-P500?
Jan 17, 2013 | Staples SPLP500 Scientific Calculator
To change the Date and Time on my Sharp EL-1801PIII Calculator your instructions refer to a faceplate, which I do not have. What keys are associated with "Time Set," "AM/PM,"...
GRAND TOTAL / RATE SETTING MODE SELECTOR:
"GT": Grand Total
"•": Neutral
"RATE SET": To set the date, time, and tax rate, set this switch at the "RATE SET" position.
Date:
• Enter in the order of month, day and year, then press to complete the entry.
• Use to separate month, day, and year.
• When is pressed, the number entered is evaluated and displayed as "date" if the
value is within the following range; "Error" is displayed otherwise, and the previously set
date is restored.
Month: 1 - 12; day: 1 - 31; Year: 2000 - 2099 (in 4 digits) or 00 - 99 (in 2 digits)
Time:
• Enter in the order of hour, minutes, then press to complete the entry.
(There is no entry available for the seconds value. The clock starts at zero second.)
• If the hour/minute digit is less than 10, it is not necessary to enter the first digit "0".
• Use to separate hour and minute values.
• When is pressed, the number entered is evaluated and displayed as "time" if the
time is restored.
Hour: 0 - 23 (24-hour system for the hour entry), Minute: 0 - 59
Dec 16, 2010 | Sharp Office Equipment & Supplies
Ho w to set the date and time
Go to the link below. You need adobe acrobat to read. THere is a section in the manual called "Adjust Date & Time"
For Date:
Put Calculator on RATE SET
Press Time/date key: enter the date using a decimal between the month, day and year (all 4 digits) please the date/time button. It should reset. (Exmple: 01.16.2009)
For time:
Leave Calculator on RATE SET
Press Time/Date key until time shows up. just like date, press the hour then the decimal then the minute. (Example if the time is 10:15 you enter 10 . 15) Press the Time/Date Key and the time is set.
This link is the manual:
http://www.sharpusa.com/files/cal_man_EL1750PIII.pdf
Jun 04, 2008 | Sharp EL-1750PIII Calculator
Set Tax Rate
First clear all w/ ON/AC.
Enter the tax rate desired eg. 7 for 7% (can you tell I'm in PA)
Press RATE then TAX+
Press C/CE.
The next time you use TAX+ it will calculate and add the value that you set.
Do the same for TAX-, you can use a different value for each as they are separate memories.
May 30, 2008 | Office Equipment & Supplies
Staples SPLP500 Scientific Calculator Logo
5,561 people viewed this question
Top Staples Office Equipment & Supplies Experts
John mullen
gbob59
Marvin
Marvin
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
