Question about Alpine TDA-7563 Cassette Player
Car stereo wired to battery and fuse box what wires go where
Posted by yohnbalzaci1 on
Jimmy D. Hendricks
    Problem Solver:
  • 6 Answers
If this is an aftermarket stereo, The red wire needs to go to a power source that turns on and off when you turn your key on and off ( a fuse in the fuse box ). The yellow wire needs to have power all the time like its connected to the positive battery terminal or a fuse in the fuse box that always has power and the black wire is the ground and needs to be grounded to the negative battery terminal.
Posted on Oct 22, 2012
1 Related Answer
Anonymous
SOURCE: instaling alpine car/cd stereo cda 9807
how do i install my alpine cda 9884 ...on a 92 caddi
Posted on Nov 18, 2008
Why wont radio turn off?
This often happens when people diy aftermarket stereo installation. Aftermarket stereos require both accessory and hot wires, while many auto wiring harnesses provide only hot leads. You must add an accessory wire from the fuse box to the stereo to prevent the battery from draining. If you are up to doing that, I can provide instructions.
Jul 21, 2017 | Jeep Cars & Trucks
Instrument panel went dead after i installed aftermarket stereo
first check the factory wiring for your vehicle. sometimes the red wire is not the battery power. In my car the orange wire was battery power and red was the accessory power. also make sure the ground wire is attached securely. Then check your fuse box. I had a 10 amp fuse blow and because the aftermarket stereo drew more power than the factory one I needed to put in a larger fuse.
Jul 03, 2012 | 2004 Pontiac Grand Prix
Best Buy installed new stereo in my 1996 Z3 - Now my stereo stops playing when I put the drivers side window down. My car recently started blowing a fuse. Help...it's been almost 4 years since I had the...
:o( you're going to have to pull the radio out to see what they did. They probably added a wire to an inappropriate circuit to power the new radio or amp. I will paste your factory wiring colors below. If you now have an extra wire, that is the likely culprit. Trace it to see where they hooked it in. If it isn't going to the the fuse box and using an extra slot, make it so by connecting it to the cold side of the fuse and put an approprite size fuse in. To determine the fuse size to use, you can compare the wire gage to other cold side wires and use a fuse the same size as you see being used for similar gage wires. Let me know if you have more questions.
1996 BMW Z3 Car Stereo Installation Diagram
Car Radio Battery Constant 12v+ Wire: Red/White
Car Radio Accessory Switched 12v+ Wire: Violet/White
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Gray/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: White
Car Stereo Amp Trigger Wire: White
Car Stereo Amplifier Location: Passenger Kick Panel
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Yellow/Red
Left Front Speaker Negative Wire (-): Yellow/Brown
Right Front Speaker Positive Wire (+): Brown/Black
Right Front Speaker Negative Wire (-): Blue/Brown
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Blue/Black
Left Rear Speaker Negative Wire (-): Yellow/Brown
Right Rear Speaker Positive Wire (+): Blue/Violet
Right Rear Speaker Negative Wire (-): Blue/Brown
Oct 26, 2010 | 1996 BMW Z3 Roadster
I am trying to wire a kenwood headunit into my 2000 fiat punto and have connected the adapters but the stereo is not working.i had the stereo in my car before with no problems.
The fiat punto does not have a ignition wire which is the problem. There are two solutions:
a) Take the Kenwood stereo back and get a Fiat stereo replacement
b) feed both the ignition and the battery from the head unit into the car 12v battery cable.
b will work but not without potential flat battery if you forgot to switch it off. Solution a is recommended
Jan 01, 2010 | Car Audio & Video
Need radio wiring for 92 astro
1992 Chevrolet Astro Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Jul 27, 2009 | 1992 Chevrolet Astro Extended
Battery Draining
Disconnect the stereo and watch the condition of the battery. Most of the time the stereo gets power out of the battery even when engine is off.
Rate this.
May 26, 2009 | 1993 Ford Probe
91 Ford Tempo - New stereo won't work ... Please HELP
here is the radio's wire color diagram, u should be able to fix the problem with this info.Fuse box is on drivers side under the dash.
1991 Ford Tempo Car Radio Wiring Guide
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Red or Black
Car Radio Illumination Wire: N/A
Car Audio Front Speakers Size: 6 1/2′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: 5′ x 7′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
Apr 12, 2009 | 1991 Ford Tempo 4 Door
CAR STEREO AND CLOCK DONT WORK, LOCATION OF FUSE 25
You are correct on checking the sterio, just 12+ and ground to see if it powers up. Fuse 25, in your fuse box should be numbered. If not, just pull them one at a time to see which one got fried.
Apr 04, 2009 | Hyundai Motor 2002 Sonata
Will not power on
Try taping the ground wire directly to the negative battery terminal, and the positive and RMT wires to the positive battery terminal, if the unit still won't turn on, check for a fuse on the unit itself, otherwise it may be dead on arrival.  If it does work, check all your car fuses, also look for inline fuses on the stereo live wire harness.  Hope this helps
Oct 29, 2008 | Car Audio & Video
Car Audio & Video Logo
99 people viewed this question
Top Alpine Car Audio & Video Experts
Jeffrey Turcotte
Jeffrey Turcotte
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
