Tried to copy to a pen drive and then paste to the new PC hard drive; received error when trying to transfer from pen drive to hard drive.
What was the error message ?
Example on how to copy data and download and save it to usb drive
Click start click on computer to open you should see your drives C: and your other drives cd dvd and your usb drive E: or F:
from there you select the files right click on the file/s right click copy navigate back to the drive right click select paste or hold the mouse cursor the file/s drag them to usb drive then drop them example on how to safe data/files to a usb drive
click start all programs accessories open windows explorer navigate to your data
right click on the data select copy navigate back to the usb drive right click select paste or select
the data hold the mouse cursor then drag the data to your usb drive then drop it in
or if you are downloading data from the internet
once it starts downloading windows will ask whether you want to run or save it
a browse option will open you can save it into a folder in my documents or another device or a
usb device
if you need more help with this post a reply
hope this helps
Testimonial: "Actually - Brian reminded me to search on the error code (I already know how to copy/paste files). "
Thanks so much for replying Brian! The MS error code is 0x80070021 ("An unexpected error is keeping you from copying the file..."). I searched on the error code in Outlook online help and found out I need to go through Task Manager to close Outlook folders. After shutting down the Outlook tasks, I was able to copy/paste the .pst files to a pen drive and then on to my new PC.
nice work well done
SOURCE: Hard Drive Data Recovery
Yess it is:
Put that hdd in another pc who have WIN XP SP2 and REMOVE JUMPER from HDD!
Download this program and recover your data:
DOWNLOAD
SOURCE: TRANSFERRING DATA
Hello
for doing that do the following
1. Place the Jumper setting as Primary master to the New HDD
2. Place the Jumper setting as Secondary Master tothe old HDD
Restart the system and copy the files from the old hdd to new
SOURCE: Moving files from Windows xp
The file on the hard drive is corrupt, run scandisk and fix the file error, but the video is likely a loss
SOURCE: cannot transfer files in to sony 4gb pen drive
try a different usb slot ..if that doesnt works then it sounds like your pen drive is damaged .. that can happen in several ways .. if you carry it around with you, make sure the cap is on ... it can get static zapped otherwise .. also the gold fingers inside can get dirty .. another way the drives are damaged is to remove them while data is still being written to the drive ... wait until the light is no longer flashing before removing .. if you are using win98 or winMe .. then make sure you turn off the device before removing ..
SOURCE: unable to transfer files to sony 4gb pen drive
Restart your PC and try it again or try it on other PCs. If problem persists then pen drive is defective. Return to retailer and ask for a replacement.
