Try going into power option settings and taking the brightness to the max there. Start, control panel, power options, then you should see a setting for battery and for plugin. Hope this helps.
I have the same model but 4g. I often notice the same problem, but once i step out of the full sun/bright lights, i notice that it is infact dimly lit. This can be adjusted by opening settings > display > brightness > turn off automatic brightness and set the level to at least %50.
now, if your screen is literally too dim to see, try this : Press the power button quickly, now unlock the screen by sliding your finger from the bottom center up to the top center and releasing, all in one fluid motion. This is the default screen-lock gesture and the brightness, if this is indeed the issue, should go up one notch upon unlock. From there, follow the above procedure to turn up the brightness.
When you say that your laptop "screen is dim", do you mean that there is no light coming from your screen, but you can see images on it? or do you mean that there is light coming from the screen, just a very little amount?
If you can images, but NO light is coming from the screen, then the LCD backlight is dead, and it needs to be replaced.
If there is light coming from the screen, but it's very dim, then you'll need to find the screen brightness adjustment keys on your laptop. This is usually two keys. The first one is normally in the lower left corner of your laptop and should be a different color - like blue or purple, and will be labeled something like "Fn". The second key is normally in the function key row (F1, F2, F3, etc...) and has a symbol on it that looks like a sun or burst of light with an arrow. There's usually one for "brightness UP" and one for "brightness DOWN". Hold down the Fn key, and then press the "Brightness UP" key a few times to see if the screen brightens up. Good luck.
Follow the 2 steps I follow all the time, retry, and restore your ipod. My itouch's screen was also really dim but when i restored it, it turned bright.
Ok on your keyboard there should be some way to adjust the brightness just plug in the laptop and adjust it to what you want then unplug the laptop and adjust it to what you want and it should keep that setting. if that does not work you can check the bios settings some laptop bios' have a brightness option.
That poroblem comes from your Motherboard and there are some trasistor that we be remove and resold anotherone where did you stay because this will be feine to an engineer to sit down and tackle the problem
ok
Rata this solutio
Step 1: Go to preferences Step 2: Go to power Step 3: Change the Auto-off after: feature and increase it to 3 minutes, the maximum.
I know this will only help it a lil from the 1 minute you had before, but if you pres the volume button or something within the 3 minutes it will restart the 3 minutes.
