How do I repair this problem???
SOURCE: Screen turning pink
If the pink overlay goes away gradually, you could have weak picture tubes (CRT's) If the color jumps in after warming up, it could be a bad solder connection. If you haven't had a good picture to watch for a long time, I would be tempted to put the money towards a new HDTV set as those older Mitsubishi Rear Projection TV's had a Lot of bad solder connections in the past, and by fixing one problem another could crop up in the near future.
SOURCE: Mitsubishi WS-55809
1)Check for coolant leak from CRT onto signal board
2)Possible convergence problem ..................T.
SOURCE: Mitsubishi WS-55809 Color
Does the neck of the tube glow? If not you may have a bad solder connection on the Red CRT PC board or a bad transistor on the red PC board
SOURCE: Mitsubishi wd-62725 screen turns pink
one of your projectors is going out...get.tech to ck..hang up when he tells you service call fee or I'll call you back lol
