Question about Apple iPad (16 GB) WiFi Tablet PC
Ipad will not power up. Apple logo flashes on/off when connected to power supply
Not used for a long time, charged for 24hrs, but will not power up, only apple logo flashes on/off
Posted by Russex on
Erik Bouwhuis
    New Friend:
    Problem Solver:
  • 5 Answers
Go to the shop you bought the iPad and they will have to try to fix it if you bought it in the last year.
Posted on Oct 23, 2012
5 Related Answers
Tim Digibrain
  • 846 Answers
SOURCE: Apple Ipad won't charge
IThe iPad needs more power than the average USB device. It doesn't run and charge at the same time on a regular USB port. If it doesn't charge with the original charger though, you have a hardware issue. You can always take it to the apple store and demonstrate the problem there, you'll probably receive a replacement. If you have issues with the warranty, there are third party places that will find our what's wrong. If you want to do it yourself, the good news is, it's not too hard to open it. Here is an iPad Repair Guide that shows how to open an iPad. If you want somebody else to do it for you go to iPad Repair NYC.
Posted on Apr 26, 2010
Jim Thomson
  • 1099 Answers
SOURCE: 3g not working on apple Ipad
As far as I understand it the ipads that have just been released are wifi only. 3g are available from late April, see the www.apple.com for details.
Posted on Apr 16, 2010
agc93
Alistair Chapman
  • 44 Answers
SOURCE: how to empty trash in
In general, an iPad doesn't have a trash at all. Since you don't have access to the file system, files cannot be user-modified or deleted, so a trash is not necessary. Further, apps will generaly take care of their own cache and data usage, so user interventions doesn't generally occur. If you are talking about mail, try using the usual delete functions while navigating the Trash folder and you should permanently delete the message.
Hope this helps, Alistair
Posted on Feb 28, 2011
Anonymous
  • 16 Answers
SOURCE: How do I Sync Outlook
To sync e-mails to your iPad, you must put the e-mail account details directly into the mail app. This is because Outlook is merely an application to download and read e-mails.
To add an e-mail account to your iPad:
1. Tap the Mail icon at the bottom of the home screen on iPad.
Step 2. Then tap to add type of email account that you want at add among: Microsoft Exchange, Mobile me, Gmail, Yahoo Mail, AOL or others. For example, if you want to add a Yahoo mail, just tap the Yahoo mail as follows:
Step 3. Then enter login details for selected email account type.
It will configure automatically and you should able to send - receive emails.
Posted on Aug 20, 2011
Anonymous
  • 5 Answers
SOURCE: I purchased an ipad in
The device that you bought is not an 'iPad'. It's actually a 'tablet'. iPad is the tablet manufactured by Apple. Now for your tablet... do a manual search for the product on the company's website. Anyways, Android is very intuitive and easy to work.. so just play around with the device for some days and you will find out how things work. If you still have some issues, post it here on fixya.
Posted on Dec 08, 2011
4answers
I have an ipad mini that's frozen on the apple logo.I've tried everything.I wanna factory restore the ipad but in order to do that I have to be connected to the internet.
Hi:
Try a hard reset. It forces your iPad to turn Off and then On.
Hard Reset Your iPad. A hard reset forces your iPad to abruptly turn off and back on, which will usually fix the problem if your iPad has frozen on the Apple logo. Press and hold the power button and the Home button simultaneously until the Apple logo appears. Then, let go of both buttons.
1helpful
2answers
My i pad is stuck in sleep mode
Perform a hard reset: Press both the Power and Home buttons and hold them down. Keep holding both buttons down until you see the Apple logo appear on the screen. The logo should appear between ten and twenty seconds after you start holding the buttons. After the Apple logo appears, your iPhone or iPad will boot back up normally.
Charge your iPhone: Connect the iPhone to the iPhone's USB power adapter and let it charge for at least ten minutes.
Get iPhone into Recovery Mode: Turn off you iPhone and just plug the USB cable into computer > Hold the HOME button when you connect USB to iPhone > Release the HOME button when you see the iTunes logo.
The Most Common iOS 9 9 2 1 9 3 9 3 3 9 3 4 Problems and Solutions
1helpful
Ipad will not turn on
You could try to do a hard reset. Hold down the power button and the home button at the same time until the device completely restarts and the Apple logo appears on the screen.
If that doesn't work you may try connecting the iPad to a computer and restoring the device using iTunes.
Hope that helps!
1helpful
Ipad will not switch on
Hope that helps!
3answers
My ipad is stucked.
This tutorial will explain how to force your iPad to restart if it gets stuck or freezes up.
Forcing your iPad to restart will not cause any loss of data - with the possible exception of any work you were doing at the time the iPad and/or App froze, forcing you to restart it.
Click and hold down the Sleep/Wake button (located on the upper-right corner of your iPad). While you're holding down the Sleep/Wake button, hold down the Home button as well (located on the front of your iPad at the bottom). Hold down both buttons until your iPad powers off. It will reboot and start again with a small silver Apple image on the screen. It takes about 30 seconds for the iPad completely start up.
Ipad is charged will not turn on
You could try doing a hard reset by holding the power button and the home button down at the same time until the device completely shuts down and the Apple logo appears.
If that does not work you may try connecting the iPad to a computer and doing a factory restore.
If none of the above work you should visit your local Apple store and have an Apple Genius take a look. Just be sure to make an appointment first.
Hope that helps!
13helpful
3answers
IPad shows blank black screen & won't turn off ~ how do I fix?
Try reseting the iPad by holding the home and power buttons simultaneously until the iPad completely shuts down and the Apple logo appears.
Once the Apple logo appears you can release the buttons. If this does not work, you may need to connect your iPad to your computer and do a factory restore using iTunes.
Forgtton unlock code on ipad2
hard reset the device
OK, you have noticed the strange behavior of your iPad / iPad 2 or even new iPad 3. It tends to freeze for about a few seconds every minute or is running too slow or something else. This is probably the best time for the hard reset of the tablet. To make things easy follow simple sequence:
  1. Make sure your iPad /iPad 2 / iPad 3 battery is charged above 20% (we would recommend at least 50 - 60 %). If you are not sure charge you tablet for at least 40 minutes.
  2. Make sure your Apple tablet is in Power On state.
  3. Watching the shining screen of iconic tablet with apps' icons on it press and hold down the Wake/Sleep and the Home buttons simultaneously, ignore the red slide "to power off", just keep both buttons holding until the Apple logo appears. This logo is the signal that the hard reset has succeeded. Be patient, some times the hard restart of iPad may take up to 10 - 15 minutes. But such a long restart is a rare case.
Be sure that hard reset retains all data and settings on iPad, it doesn't delete anything. If you want to start over and delete all personal data from iPad you should use iPad Recovery Mode.
Apple iPad (16 GB) WiFi Tablet PC Logo
Top Apple Tablets & eReaders Experts
nexrad_chris
Vernon Taylor
NOEL
NOEL
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
