SOURCE: cd rom problems
I just replaced the CD drive in my 2200, the eye went out. You can check to see if it's the drive or drivers by uninstalling the drivers from the device manager, then reboot. It will find the drive and reinstall the drivers. If this doesn't fix it, then the drive is bad. The drivers for optical drives are very simlpe, some times they will glitch and need to be reinstalled, but most of the time it's the drive that has gone out.
SOURCE: cd-rom, computer won't load.
You will need to call our technical support line on 0845 20 20 118
SOURCE: cd/dvd rom is not recognized on system. No drive letter or in device manager
If the drive is showing an error (or is missing) in device manager, do the following:
Start Registry Editor (Start, Run and type in regedit then click O.K)
Locate the UpperFilters value under the following key in the registry:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
On the Edit menu, click Delete, and then click OK.
Locate the LowerFilters value under the same key in the registry:
Quit Registry Editor.
SOURCE: my cd-rom will not open. What should I do?
It sounds like the drive spring is bad. There's usually a small hole on the drive itself, you can stretch out a paper clip and stick the paper clip in the hole to see if it will release. If it releases, the drive's not picking up on the power being delivered by the system. See if you can swap it with another drive.
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Click on
Enter
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder
Upper
Filters
Lower
Filters
Upper
Filters.bak
Lower
Filters.bak
Hope this helps
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Hope this helps
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Click on
Enter
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder
Upper
Filters
Lower
Filters
Upper
Filters.bak
Lower
Filters.bak
Hope this helps
Click on
Enter
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder
Upper
Filters
Lower
Filters
Upper
Filters.bak
Lower
Filters.bak
Hope this helps
if your computer came with
a motherboard disc the drivers could be on it
Click start control panel administrive tools computer
management device manager scroll down cd-dvd rom drives you might see a yellow
question mark ? right click you will have options to update driver
hope this helps
click start control panel,administrive tools,computer
management,device manager scroll to cd/dvd rom drives right click properties
then properties again then tick enable cd
digital cd audio for this cd rom device or scroll to dvd regions select
the no _ for your specific area or if this fails to fix the problem
Click start control panel,administrive tools,computer
If this does not fix the
problem you might try
you might have to
physically unplug the leads for this cd-rom then plug them back in this
should activate the found new hardware wizard or
you might have to uninstall
then reinstall your DVD/CD or uninstall the driver then reinstall for this
device
admistrive tools,computer management,device manager scroll down cd dvd rom
drives right click you will see options to update driver,roll back
driver,or
select properties general
troubleshoot, select driver click to reinstall drivers click update
driver or uninstall then reinstall
make sure that the cd-dvd
burner is getting enough power test all leads that are attached to the dvd
drive including electrical extensions and make sure they have a secure
connection or just replace them there might be
bad/faulty or
if this does not fix
the problem it might be a registry problem
Close all open
programs
Click on
Enter
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder
Upper
Filters
Lower
Filters
Upper
Filters.bak
Lower
Filters.bak
hope this helps
please be more specific. is it a new install, working before or changes done prior to the condition?
hi again, although i might want to agree with Mohammad Atiqur Rahman's response i feel its a bit premature to assume anything without further feedback. Kindly elaborate further.
its not a new install was working very well before and i am seeing any thing about cd rom drive in device manager though if i press the button of cdrom drive it is coming outand can green light alsodrive
its ... not seeing anything in about cdrom drive in device manager and its coming out if i press the button and can also see green light
how can i check if port is damaged
U mean to say cd rom to try in another laptop. could it be also bcos of drver problem
