We were watching the T.V and it went "pop" and shut down. We unplugged it and now we can get sound but no picure. Any ideas?
Take a flashlight and at a angled view see if you can see the picture, if you can the lights burned out in the back
Posted on Oct 22, 2012
SOURCE: My 73'' mitsubishi model #wd-73738. Is flickering.
Hi!
That's a clear indication that you have a bad power supply in your TV.
If
you know how to DiY...I suggest you open your TV. Locate the power
supply section, it is where the end of the power plug is connected.
Replace all blown or bulge or leaked capacitors with same value. That
will fix your TV problem.
The hardest part is to disassembling your TV cover, cause you will need to pry off the snap in lock at the edge of your TV.
Power supply board should look like this. Examine the capacitors in the board
After replacing blown capacitors...it should work again.
Things you will need.
1. A plastic flat end screw or any object with flat ends....to fry off the cover
2. Soldering iron.
3. Soldering lead
4. Soldering pump.
5. Flat and Philip Screw
6. Replacement capacitors (of same value with the blown one) that you can buy to any electronics store.
Or try replace light engine..if the above solution won't work..
Posted on Feb 23, 2012
Oct 15, 2015 | Mitsubishi WD-73738 73 inch DLP 1080p...
Oct 14, 2015 | Mitsubishi WD-73738 73 inch DLP 1080p...
Dec 15, 2014 | Mitsubishi WD-73740 73" DLP 3D 1080p Home...
Aug 18, 2014 | Mitsubishi WD-73738 73 inch DLP 1080p...
May 17, 2014 | Mitsubishi Televison & Video
Mar 25, 2014 | Televison & Video
Feb 23, 2012 | Mitsubishi Televison & Video
Nov 23, 2011 | Mitsubishi WD-73837 73 in. HDTV
Dec 17, 2010 | Mitsubishi WD-73734 73" Television
Aug 26, 2010 | Mitsubishi WD-73827 73" HDTV DLP TV
582 people viewed this question
