Question about RIM BlackBerry Pearl 8130 Cellular Phone
How to insert the sim card into BlackBerry 8130
Posted by proudmorethe on
Laurie Graham
    Sergeant:
  • 307 Answers
Try this website:
https://m.youtube.com/watch?v=LaNbdeLzj4s
Posted on Mar 11, 2019
Brian Parker
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 44 Answers
If this is a Verizon phone then it most likely does not have a SIM card. If it does have one then it should be located under the battery. If your phone has a SIM card, here are the instructions for removal. Just reverse for install.
http://www.ehow.com/how_5752031_remove-sim-card-blackberry-pearl.html
Posted on Oct 21, 2012
5 Related Answers
tim
  • 84 Answers
SOURCE: Unlock CDMA Blackberry phone for other networks
unlock your CDMA Blackberry eaisly with Imei Unlock code. first call your service provider ask your Mep Code. But it takes time to give your Mep Code. or other option is go online. there are thousand of sites available to provide Blackberry Unlocking Codes. Buy your unlock code from third party. i hope this information is help you :)Good Luck
Posted on Oct 13, 2011
ipodslinger
Steve Brown
  • 688 Answers
SOURCE: Need to replace keypad on Blackberry Pearl 8130
Hi Keith,
if you have knowledge of how the phone disassembles you can remove the screws in the back
and open the phone by using a razor bladed and popping the plastic lockes around the edge
Check out this youtube tutorial before you do anything. if you feel ok to do it, it's you phone.
But be warned the plastic is delicate so be sure you have patience and work slow.Hope this helps, if so leave a FIXYA Vote
Posted on May 13, 2009
awsolutions
  • 55 Answers
SOURCE: blackberry flip keeps going to insert sim card and
need to adjust Sim tray try putting something to hold it a sticker or tape some small paper.
Posted on Jul 13, 2009
SOURCE: my blackberry pearl error message
You may have a bad SIM card. Tmobile may give you a new one or you can buy one for about $20. Then call them to have the IMEI number switched over.
Posted on Aug 29, 2009
Anonymous
  • 6 Answers
SOURCE: y blackberry keeps saying insert sim card when its
check that the sim card is clean and not damage din anyway. Also check the connections on the blackberry where the SIM goes.
If the problem persists then go back to your network provider and see what they suggest. If they cant help maybe contact blackberry.
Posted on Oct 25, 2009
Hi i had purchased a 8130 pearl Blackberry from us.It is locked to verizon.I am now back to india.i want to use it with other cdma provides.how can i do it as this phone does not have any sim card...
You need blackberry pearl 8130 unlock code for verizon network to unlock your phone so you can use any of india cdma network on your blackberry pearl. Blackberry unlock code can be obtained from your original phone network provider and third party sites. Both of them take some charges, but third party sites more cheaper and more quickly rather than asking unlock code from network provider.
Apr 06, 2011 | RIM BlackBerry Pearl 8130 Cellular Phone
How to Unlock Blackberry Pearl 8120?
Instructions for unlocking Blackberry Pearl 8120
1. Ensure a SIM Card is inserted
2. Go to 'Manage Connections'
3. Click on 'Turn All Connections Off'
4. Go to 'Options'
5. Click on 'Advanced Options'
6. Click on 'SIM Card'
7. Type 'MEPPD' (letters will not appear on-screen but a menu will pop up.)
8. Type 'MEPP2' (*Note- for Telus, use MEPP4. You will be prompted to enter MEP code)
9. Enter the unlock code (CONFIRM you get "Code Accepted" message)
10. Reboot device
11. Go to 'Manage Connections'
12. Click on 'Restore Connections'
13. Device is now unlocked
http://unlockgenie.com/Unlock-Blackberry-Pearl%208120
Jan 28, 2011 | RIM OEM Blackberry Pearl 8120 8130 Flexi...
Trying to activate a unlocked Blackberry Pearl 8130 for cellular south carier
you Need to Unlock your Blackberry Pearl 8130 for south carrier or any network.
you can unlock your Blackberry bysimple entering unlock code through key pad, after unlock your Blackberry youcan use it with any GSM SIM card around the world. I know this trust fully Blackberryunlock code provider. I hope this Blackberry unlock code will very help fullfor you
Nov 17, 2010 | RIM BlackBerry Pearl 8130 Cellular Phone
How do I remove the sd card from the 8130 blackberry pearl?
As you look at the phone, in the left side is a door with a simbol on it like a SIM card. Open with carefull that door and you`ll see a black line about 3 mm thick. Press on it and you`ll hear a click then remove your finger and the card should pop out.
Nov 07, 2010 | RIM BlackBerry Pearl 8130 Cellular Phone
I have a BB Pearl 8130 from Telus that I need to unlock (no sim)
Go to http://blackberrymep.com , and follow instructions there, then you will your unlock code with instructions to enter it .
Mar 01, 2010 | RIM BlackBerry Pearl 8130 Cellular Phone
Blackberry pearl 8130 locked by personal code
You can reset the phone by going to Options > General Settings > Security > Blackberry button and wiping the entire handheld.
That usually does a pretty good job of clearing the handset. If that doesn't do it, then you might have to reflash it by going to the carriers website and redownloading the software.
One final thing - it might be the PUK code. If thats the case, then try putting your SIM card into the phone (if its a GSM Blackberry)
Aug 25, 2009 | RIM BlackBerry Pearl 8130 Cellular Phone
My blackberry 8320 said my sim car rejected
check whether sim card is working in different mobile or not ......if not working replace the simcard with the new ...
Jun 16, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
I need to unlock my alltel pearl 8130
contact service provider for unlock code and if u have the unlock code follow the below procedure
1.menu-->manage connections-->turn all connections OFF.-->
2.select menu--->options-->advanced options-->sim-->press MEPD and MEP2--> enter the unlock code -->press enter
3.Do hard Reboot (Take out and battery and reinsert sim and again insert battery.restart the handset)
Jun 10, 2009 | RIM BlackBerry Pearl 8130 Cellular Phone
Cant find where to insert san disk card
If you have a blackberry pearl 8130 then the Memory card slot should be on the left side of the phone above the application key.  If it is a 8110 the memory card slot will be underneath the battery.  Hope I helped.  Oh and I don't believe you can put the memory card into the MacBook, you have to transfer files with the bluetooth on both your phone and your Mac.
May 07, 2009 | Verizon Communications BlackBerry Pearl...
How do I change the SIM card in my BB Pearl 8130
Take SIM card out of old phone and put it into the new phone, however first of all you need to backup your old device.
Download the Desktop Manager and connect via USB cable and backup old handset, insert usb into new phone and restore to new phone thus moving all data from old to new.
Gadget
Dec 03, 2008 | RIM BlackBerry Pearl 8100
RIM BlackBerry Pearl 8130 Cellular Phone Logo
581 people viewed this question
Top RIM Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Vincent G
Vincent G
Marvin
Marvin
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
