Name : Nurfadzwin Product Name : Samsung YP-U3 MP3 Player Please help me ... I have to use it as soon as possible ... Please ...
SOURCE: Samsung YP-U3 MP3 Player Problem connection
Found the solution on another site (http://www.everythingusb.com/forums/showthread.php?threadid=11238). To quote user AFHavemann :
"* Plug in the player so the USB bus can see it.
* Once it’s recognized (i.e., the device screen reads "Charging" and "USB Disconnected"), go to the Control Panel and click "System"
* Choose "Hardware" then "Device Manager" tab.
* Look for the name of your device under “Portable Devices” in the list
* If the name of your player is under “MTP Device” then the correct drivers are probably loaded
* Right-click on the name of your device and click "Properties"
* Click “Update Driver”"
Then follow the prompts from there. The computer searches for the driver software, etc., and reinstalls/resets information related to the device, which fixed things such that the computer will now recognize the device. I'm not sure what causes the problem, but this solution seems to reset whatever's gone wrong.
SOURCE: disconnected samsung mp3 player
Gday...the most likely issue concerning the "USB Disconnected" message
on the U3 is that the device has installed itself with incorrect
drivers. If this is the case then following these steps should rectify
your problem...
1) Plug the MP3 player into the USB port
2) Open up Device Manager (Start, Settings, Control Panel, System, Hardware, Device Manager)
3) Find Samsung UP-Y3 in the list (should be under "Other" or "Portable devices" with a ? next to it)
4) Right click on this and select Uninstall
5) Remove the player from the USB port and plug it back in
Windows should automatically detect the device and install it's own
drivers. If not, and you have a driver disk, then just install the
Samsung drivers. You should now be abe able to drag and drop files onto the player using Windows Explorer. Hope this solves the issue.
Cheers,
Scott
SOURCE: Hi ! i have a samsung YP-U3 Mp3 player which is
try to "format" it. there's a format button in the settings of the mp3. i tried it. :|
