This is because either the image on the hard drive is bad (corrupted, missing boot sector, etc) or because the hard drive itself has some issue like corruption etc.
If this is a mirrored raid array (two drive mirroring each other) I would try to remove one of the drives and boot again. If that does not work reinsert and remove the other drive and try to boot.
regards,
Mike
SOURCE: HP Proliant ML370 Server: Very Urgent Please
Open the system cover and check whether any LEDs showing amber or Red colour
SOURCE: HP Proliant ML370 Server: Led shows red light
Your server definetly has issue booting first of all this is a little old server model so first open and blow air from a blower (¬ use vaccum cleaner)
since problem could be anything frm a struck cpu fan or anything
then poer donw theM/c and locate the RAM its a smal hardware in green color vertically fitted to the motherboard it will have locks at the both ends press them downwards the RAM will pop out then clean the side that was inside the motherboard with eraser and nothing else(it might damage the RAM) then fix it as it was aligning the notch it should work
If this does not work out then tell me exct LED and sybol near it
Bye for Now
SOURCE: My HP Proliant ML370 server has no video. Can I
There is standard Integrated ATI Rage XL Video Controller with that server.
SOURCE: my HP Proliant ML370 G4
dear erwin,
as per your writing the server raid has broken .. its may be a problem with a hard disk , first you have to check the hard disk state . to do that you should enter into raid bios . don't try to something on that , just see the status of logical drive then which are the disks includes on that raid
in you post also it may give the details of failed disk ids
then you may have problem with your batt. unit , for that please do the above steps first then back with that...
SOURCE: Can the HP ML370 G3 be upgraded to windows server
Unfortunately hp does not have drivers for ML370 G3 on windows 2008 this OS cannot be installed in this server, i attached the os matrix so that you can confirm.
OS Matrix
ML370 G3 OS
