The remote just stops working for 20 mins or so, i have replaced baterries with new ones and have now bought another brand new remote but the fault is still there. the tv is is 2 years old and is out of warrenty
SOURCE: my remote is not responding to the tv even i have changed the new baterry
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
SOURCE: remote and fan stopped connecting -- no changes and batteries are new
Is it infrared remote? If so you can check my instructable how to repair remotes: http://www.google.co.nz/url?sa=t&source=web&ct=res&cd=1&url=http%3A%2F%2Fwww.instructables.com%2Fid%2FRepair-your-remote-controls%2F&ei=mpVVSrr6O4_-sgP0-oDPDg&usg=AFQjCNGyomjVuVMr6mFT1L36ffi06FhCDg&sig2=kheNi9TulBWzmhGOMiIX7g
SOURCE: my remote for the harmony 550 says welcome to
First I would check to see if any of your buttons are sticking. I have found that this is a common problem with the 550 remote. I really like this remote but if nothing works check your buttons to see if any are pressed under the plastic. This remote can only work one button at a time so if one is being pressed it will not work.
SOURCE: remote control code for a daenyx tv
My Daenyx DN-191 D TV remote stopped worked after a while. I didnt get one universal remote that works with this piece of junk. I called their customer service at 1-877-329-8351. They said the remote will be $30 + $7 (shipping) + tax. Your best bet will be to buy a replacement remote or better toss this junk off the window.
SOURCE: Need universal remote code for a 19in genesis tv.
the keys on my remote stick. How do I solve. Also, I want to trade TV's and I need someone to come reinstall.
