You have to reset your whole phone. Hold the power button and the volume button down at the same time until Pantech pops up on the screen and when it does let go of the power button but keep holding the down volume button down. When the triangle pops up let go of the volume button and press the menu button. Use the volume button to scroll down to wipe data. Hit the home key.. scroll down again to yes and hit the home key. Hit the home key again on reboot system. That's it ! :)
SOURCE: my pantech impact keeps on
There are widespread complaints regarding this phone's random restarts. The possibility is that you acquired a refurbished phone. You have two options in order to get rid of the random restarts at this point: 1. To trade in your phone. It would be helpful if it is on warranty 2. Obtain a new phone
SOURCE: MY PANTECH KEEPS RESTARTING ITSELF
Remove battery and clean the contacts. Now reset the battery and restart the phone , make sure that the phone boots well without any time lag. If not there can be errors in the software.
If there is shut down without any action the fault can be related to a hardware issue and might need expert view and assessment.
SOURCE: My Pantech Pursuit restarts everytime
I found a simple solution, although its a pain... you have to format the system memory but going to My Stuff, Used Space, then tapping Format. you lose ur stuff, but i just tried this cause mine had the same problem about 5 minutes ago and now it seems to be working like normal again
