Acer Aspire 5610-4648 Notebook Logo
A
Anonymous Posted on Oct 20, 2012
Acer aspire 5253-bz656 no bootable device - Acer Aspire 5610-4648 Notebook
4 Related Answers
leecom72
Lee Hodgson
  • 4810 Answers
  • Posted on Aug 06, 2009
SOURCE: acer aspire one
Its possible the computer is trying to boot from another device, as the computer starts up hit the F12 key, this should bring up boot options, select HDD if it's in the list.
If not hit F2 as it starts and enter the BIOS, look for the boot option and set the HDD as the first boot device, hit F10, save the changes and exit.
The computer will restart and hopefully boot into the operating system
Please post back if you need anymore assistance.
Regards.
Anonymous
  • Posted on Jan 16, 2010
SOURCE: my acer aspire one says no bootable device
This sounds awful, but a friend just had the same problem - no bootable device. He had dropped it, hitting keyboard first. Now he thumped it on the opposite side and IT WORKED! Must have been a loose connector
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on Jan 26, 2010
SOURCE: Acer aspire - PXE-E63: error while intitializing
You need to set the PC to BOOT from the Main Hard Drive, & NOT to boot from network, which looks like what it is trying to do now?
FordFan101
  • 45 Answers
  • Posted on Feb 14, 2010
SOURCE: my acer aspire 4810t says no bootable device
enter BIOS - you will see a mesage when you first turn on laptop tellign you to press a key to enter setup. Do this and make sure HDD is listed. if it is, you might have todo a recovery.
Turn on laptop, then immediatly press ALT + F10 keep finger on ALT and press F10 a few times, this will start the recovery process. some ask if you want to re-install windows or full factory reset. Windows install will only repair it - full factory reset will delete any data you have! so be careful
Flash bios on acer aspire 5253
Go to Acer's website to get Bios updates.
Add audio input device on Acer aspire 5263 series
Acording to the data sheet there are a mic and line in ports on the laptop.
Where is cmos chip located on 5253-bz656 acer
How to get rid of the bios password on Acer Aspire AS5253 BZ661 Laptop...
You'll need to disconnect the main battery and the cmos battery so no power goes to any part of the system.
Acer aspire 5253
buy a bootable disk or burn or try to use flash drive using universal USB intaller
Keyboard settings
Go to "Regional and Language Options" in the Control Panel and change the keyboard to English.
Acer aspire 5253 error message no botable device after laptop was dropped on carpet
No bootable device suggests that your Acer Aspire hard disk may have been damaged when the computer was dropped.
You should try opening the cover on the base of the laptop where the hard drive is fitted and check to make sure that the drive is seated firmly and has not come loose with the drop. See the Acer Aspire 5253 Quick Start Guide for the location of the drive cover.
If reseating the drive does not help, then you would need to find any recovery discs that you may have made or received with the laptop plus need to buy and install a replacement hard drive.
I need a owners manuel for my acer aspire laptop 5253-bz656. this is my first laptop and need to learn things about how to use it.
Here is the generic user guide:
http://global-download.acer.com/GDFiles/Document/Generic%20UG/Generic%20UG_Acer_1.0_A_A.zip?acerid=634267681865563989&Step1=Notebook&Step2=Aspire&Step3=Aspire%205253&OS=722&LC=en&BC=Acer&SC=PA_6
And here is the larger user guide:
http://global-download.acer.com/GDFiles/Document/QuickStartGuide/QuickStartGuide_Acer_1.0_A_A.zip?acerid=634305054989908375&Step1=Notebook&Step2=Aspire&Step3=Aspire%205253&OS=722&LC=en&BC=Acer&SC=PA_6
Thanks and a vote/feedback is always appreciated. =)
I am looking for the setup and operating manual for an Acer Aspire Model 5253-BZ656 laptop. Any suggestions where I can obtain one?
Here is the link to the ACER support page:
http://www.acer.ca/ac/en/CA/content/drivers
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated.
When you get there select the following from the drop down lists:
NOTEBOOK
ASPIRE
ASPIRE 5253
Then select the DOCUMENTS tab.
Then click on the orange download button beside GENERIC UG Version 1.0
Just SAVE that file on your computer.
Once that download is complete you can also download the QUICKSTART GUIDE as well.
That is the one right below the GENERIC UG and downloads the same way.
You may need ADOBE READER installed on your computer to read PDF documents. You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, and then just follow the onscreen instructions to install it.
Thank you and good luck.
1helpful
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
