Upon trying to print a document from Apple Pages 09, I receive the message in printer box that "filter failed".
SOURCE: Paper Out message
Make sure that you are loading it in the back and not the front, I didn't figure this out until I looked at the manual. If you're used to HPs then you want to load in the front, but actually if you look behind the scan door, there is a black panel that you can open, and that's where you feed the paper. That thing in the front is actually where the paper comes out of. Go figure.
SOURCE: Hi have an MP560 and
You will need to re-download the printers drivers and then restart your computer for the changes to take effect. Your current driver has become corrupt. Click on the link below and then select your operating system to get started:
http://www.usa.canon.com/cusa/consumer/products/printers_multifunction/photo_all_in_one_inkjet_printers/pixma_mp560?selectedName=DriversAndSoftware
SOURCE: My Canon MP470 is printing
During certain cases, you might have completed the physical integration perfectly. But still, you might not be able to accomplish the printing. This could be due to the absence of a driver installed in to your system. The problem could easily be averted, if you are installing the driver corresponding to the manufacturer. You might ensure that the version corresponds to the exact version of the printer series also.
SOURCE: pstopdffilter/pstocupsraster failed with err
Obviously this is an error coming from Adobe and not the printer. So I was start with Adobe and see what solutions they have to offer. Also, maybe I missed it somewhere, but you didn't say what OS you're using. I'll assume mac since I thing that I've seen that error related to Mac and Adobe Reader. One thing you might try is to use "open with : preview" and print from there. Don't know if that will work or not, but it's worth a try. In any case, I would still inquire through Adobe for possible updates or fixes.
SOURCE: I have a canon MF 8350 cdn and when i try to print
Check paper size refers to the fact your documents are for say and A4 sheet of paper but your drivers properties are set to letter size. Go into the drivers printing preferences and set the paper size to the correct value. All should work fine now.
