Question about Pride Mobility Products Health & Beauty
Wiring diagram for Pride GoGo mobility scooter
I need the wiring diagram
5 Related Answers
gewiz
Rob Hill
  • 1414 Answers
SOURCE: PRIDE GOGO ULTRA X Beeps and Cuts off
Please make sure your charger is okay, can you try another charger ?
the other thing is , the FREEWHEEL lever can it move itself say when you go down a kerb , what are they replacing ? do you have the part ? send me a photograph if you do ?
Posted on Jun 13, 2009
Anonymous
SOURCE: Need a wiring diagram for Pride Rally Electric Scooter
I can tell you how i fixed it for $19.95
Posted on Jun 22, 2009
Anonymous
  • 350 Answers
SOURCE: where and how do I replace my battery for my pride
Do not use batteries with different amp-hour (Ah) capacities. Do not mix old and new batteries. Always replace both batteries at the same time.
MANDATORY!
Battery posts, terminals, and related accessories contain lead and lead compounds. Wear goggles and gloves when handling batteries and wash hands after handling.
WARNING! Always use two batteries of the exact same type, chemistry, and amp-hour (Ah) capacity. Use 12 Volt deep cycle batteries.
1.Remove the battery pack from the Travel Scooter.
2.Carefully turn the pack upside down.
3.Remove the eight (8) screws from the perimeter of the battery pack.
4.Carefully turn the pack right side up and remove the lid.
5.Disconnect the black (-) and red (+) battery cables from the battery terminals.
6.Remove the old battery.
7.Place a new battery in the battery pack.
8.Connect the red battery cable to the positive (+) battery terminal.
9.Connect the black battery cable to the negative (-) battery terminal.
10.Position the lid back onto the battery pack ensuring all wires are inside the pack so they don’t become pinched.
11.Carefully turn the pack upside down.
12.Reinstall all screws and tighten.
13.Charge the new batteries for 8-14 hrs before the first use.
I hope this helps and good luck!
Posted on Feb 24, 2010
Neil Wood
  • 177 Answers
SOURCE: Pride Celebrity Deluxe Mobility Scooter - Serial Number
Hi. The serial number will be on a sticker on the upright support that holds up the seat. You will have to lift of the seat, and take the cover off the batteries to see it. It should be on the front of the deat support. Neil.
Posted on May 27, 2010
Neil Wood
  • 177 Answers
SOURCE: wiring diagram for sc234ala mobility scooter
Hi. Do you need a basic wiring diagramme for the lights, motors etc. or do you need one for the controller? What faults do you have?
Fisher and Paykel sold their mobility scooter business to Plega Healthcare in Australia. Plega now no longer suport the mobility scooters.
We have some parts left in stock, and were an authorised service agent for these machines.
No one was ever supplied with a circuit diagramme for the controllers.
We do have all the service manuals here and have a full set of the fault codes.
You can email us at [email protected]
Good luck. Neil.
Posted on Jul 24, 2010
Wts gogo scooter just keeps beeping whenu switch it on whats that mean
this could mean the scooter is not in drive try the free wheel lever first.
Feb 25, 2015 | Pride Mobility Products GoGo Elite...
My gogo elite traveller wont chrage. The charging light isnt on when i plug the scooter in.
Sounds your batteries are to low in voltage for the charger to recognize. Also check the fuse on the battery box, normally a red one 10amps.
Feb 13, 2015 | Pride Mobility Products GoGo Elite...
My Pride GOGO scooter is stuck in drive and wont go into freewheel?
The park brake has got stuck, the brake needs to come off and be stripped down and cleaned, this will sort it.
Jul 25, 2014 | Pride Mobility Products GoGo Elite...
Wiring diagram on a gogo scooter
The wiring interconnects on these scooter are all modular and the blow up assembly diagrams are all you need to trace the wiring and replace components. Aside from a dealer log in to the manufacturer's website you can go to southwest medical's website and get all the information on the wiring and parts. Hope this helps.
SC40X Go Go Ultra Replacement Parts
Mar 01, 2014 | Pride Mobility Products GoGo Ultra X...
Where can i buy repair maual for gogo ultrx 3 wheel scooter
GO ON-LINE TYPE IN THE WEB SEARCH PANEL ...GOGO ULTRX 3 WHEEL SCOOTER MANUAL, YOU'LL FIND OUT MORE THAN YOU'LL PROBABLY WANT TO KNOW...
BUT YOU WILL BE ABLE TO EITHER DOWNLOAD THIS MANUAL AND SAVE IT TO YOUR COMPUTER,
OR ATLEAST RETREIVE INFO ON WHO THE MANUFACTURER IS AND INFO OF HOW TO CONTACT AND THEY WILL EMAIL YOU THE DIAGRAMS IF REQUESTED OF WHAT PART NUMBERS ARE FOR YOUR SCOOTER!
HOPE THIS HELPS,
MARTIE
Aug 25, 2011 | Pride Health & Beauty
Have GOGO scooter, when you turn it on the alarm sounds and will not to anything, it has been fully charged.
Princess try the freewheel lever make sure its in the drive mode and turn the scooter back on Hope this helps
Mar 26, 2011 | Pride Mobility Products GoGo Ultra X...
Where can I find a repair manual for a Pride GOGO Elite Traveler Plus?
Contact Pride Mobility at 800-800-8586, they are usually around $20.
Nov 06, 2010 | Pride New Mobility Victory XL 4 Wheel...
Jun 10, 2009 | Pride Mobility Products Go-Go Elite...
Health & Beauty Logo
1,212 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Bird
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
