To make watch band smaller
Click on this link for instructions
http://www.watchmaterial.com/How_to_size_a_watch_band.asp
SOURCE: Remove link form Relic Wrist band
For my relic ZR15372, all I did was take a thin, hard object (a thumbtack in my case) and carefully pushed out the connecting bar from the link.
If you look at the inside of the band of your watch, you may notice that on some of the links (the ones nearest the clasp for me) there is a little arrow pointing at the side - if you look at the side of the links, there should be a little hole, big enough to push a thumbtack into. If you apply enough pressure (again, carefully - no need to stab your thumb or any other part of your body), the connector pin should slide out a little on the other side. Then it's just a matter of pulling the pin out - perhaps a pair of tweezers would do the trick.
Hope this works for you!
SOURCE: tessot steel wrist watch band
i own a tissot too. instead of removing a link, just change which hole the link sits in on the clasp
SOURCE: Invicta 2875 wrist watch band too large
You may or may not have
arrows inside bracelet.Arrows are pointing the way the pins must come
out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws.
If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx.
size of pin end diameter using any sharpening stone or sandpaper. Get
an old towel and fold it to make a soft base for work (like small
cusion). As you don't have a special bracelet holder you will need a
pair of helping hands to hold the bracelet steady upright. You will
need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make
sure that the grooved pin ends are facing towel, not the needle and
hammer!!!
Now place the watch on the folded towel, take that needle and smallest
hammer you have and start driving the pin out using light blows. Do Not
hit hard, as you will brake the needle, scratch your watch or even
injure yourself. Watchmakers are using 45 gram hammer, so, calculate
your strength of blows.
After a few blows check if the split end is coming out and when you see
that the end is long enough to grab it with pliers, pull the pin out
with pliers. When pulling, do NOT turn pliers, as pins tend to brake
when twisted. Use firm grip and your strength to pull the pin without
twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY
the same way as they came out- the blunt end first in the hole and the
split (grooved) end last. Before doing that check remaining pins in
bracelet to make sure that you put them back from the right side of
bracelet.
It is recommended to use plastic hammer to drive pins back in or you
will scratch or damage bracelet. If plastic hammer is not available use
an old toothbrush handle (or some plastic item) as an absorber. Simply
put pin into the hole as deep as you can with your fingers, put the
toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
