SOURCE: 1997 Cheverolet z71 blinker problem
the most common problem is the light boeard in the tail lights usually replace the board full of bulb sockets and that takes care of it but before condeming the board make sure you are getting power to it
SOURCE: Chevy Cavalier 2001 turn signal blinks fast
If new bulbs don't work, it is probably the harness that holds the bulb. I had to replace both on my car after fighting with the problem for over a year and not knowing.
SOURCE: left rear turn signal light on my 1999 chev. s10 is not working
any increase in bink speed is direcly related to a bulb being burt out.
SOURCE: left and right rear brake lights are out. center
it sounds like you need to replace the turn signal switch ( also known as a multifunction switch). The brake lights also go through that switch; You will have to remove the cover from around the lower part of the steering column to gain access to the switch.Hope this helps. Please leave comment.
