This is a Samsung 357 which can be hooked up to cable but all I'm interested in at the moment is playing DVD's on the TV. I have an old TV with a built in VHS player. It has only the yellow and white conections. Is there a reason why the DVD won't play. It just kees ejecting the DVD. Do I need something extra for the red connection?
SOURCE: quasar tv/vcr combo vv2009
clean the head of your vcr if that does not work then you will have to call in the tech to look into your problems goood luck.it is probably the color circuit
SOURCE: Hooking up a DVD player to a Quasar TV/VCR Combo
Yes, for a workaround. The adapter would be 2 RCA female to 1 RCA male. You have to connect both the red and white to the female RCAs and use the male to connect to the TV's Audio INput. The yellow goes to the video. There should be no negative technical effect other than lost of stereo quality. The audio output of the DVD is line level and could normally tolerate this condition.
The correct method is to use a simple line level audio mixer and mix the L& R audio signal to produce a mono signal or to use a stereo amplifier for the sound output.
Hope this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
